ᐅ How can I make MALM furniture child-safe?
Created on: 6 Jun 2020 09:13
Nanonon
Hello everyone, I have purchased some MALM furniture from IKEA, but I have small children at home and would like to make the furniture childproof. My main concern is the tipping risk of the tall dressers, and I also want to prevent the drawers from being pulled out completely without supervision. Do you have specific tips or proven methods for making MALM furniture child-safe without ruining the look? What materials or techniques work best for mechanically securing the furniture, and are there any recommended products that fit well? I appreciate any advice and experiences!
Raymond
6 Jun 2020 13:57
I believe that safety is not achieved solely by securing furniture to the wall. Children react differently; some try to bypass all safety measures.
In addition to anti-tip brackets, so-called "anti-slip pads" under the furniture are recommended, as they can prevent sliding and unusual tipping. It can also be helpful to store heavy items in the lower drawers to lower the center of gravity.
For drawers, you can also use adhesive wheel locks that make pulling them out more difficult but do not completely prevent it.
In general, the more safety features combined, the better.
Nanonon
6 Jun 2020 15:45
Thanks for all the tips so far. I have one more question: Regarding wall mounting – how reliable are the standard anti-tip brackets from IKEA? I have read online about cases where the brackets didn’t hold during strong pulling by kids. Would it be better to use more robust screws or anchors? Are there any practical experiences on what to pay attention to during installation?
PLOMA
6 Jun 2020 16:12
Nanonon schrieb:
How safe are IKEA’s standard anti-tip fittings when mounting on a wall?
IKEA’s standard anti-tip fittings are generally sufficient for typical use and to prevent accidental tipping. However, the safety largely depends on the quality of the installation. The included screws are often shorter and designed mainly for wooden surfaces or solid walls.
If you have drywall (plasterboard), I recommend using hollow wall anchors with higher load capacity. For concrete or solid brick walls, shorter anchors are not adequate; in these cases, longer and suitable anchors and screws should be used.
Make sure the fittings are installed level using a spirit level and that screws are tightened fully. A loose element can easily give way under load.
I also suggest testing the fittings after installation by applying a pull to check they hold securely. If not, it’s better to use higher-quality components from a hardware store.
Giagau
7 Jun 2020 08:23
Regarding screws and anchors: choosing the right wall fastener is the most important factor for stability. For drywall, I recommend heavy-duty anchors or metal ribbed anchors, which provide better load distribution.
The wall itself is also important: load-bearing walls are more suitable than partition walls. If possible, attach the fixture to a wall stud (e.g., wood), as this significantly increases holding strength.
For drawers, you can additionally use safety latches that are discreetly installed on the inside.
nofomu
7 Jun 2020 11:02
Regarding drawers: Use magnetic child safety locks, installed inside. Attach the tilt lock to the wall, choosing the appropriate wall plugs (anchors).
Deoma
7 Jun 2020 12:44
I use a combination of tilt-lock safety devices and soft-close drawers for my Malm dressers: these make opening more difficult and prevent sudden drawer falls. Additionally, I recommend corner protectors for edges; this is especially important when children start to walk.
