ᐅ How can I modify Malm furniture to make it more child-friendly?
Created on: 31 Dec 2024 10:17
tesau
tesau
31 Dec 2024 10:17
I am planning to modify some IKEA Malm furniture in my home to make it better suited for small children. Specifically, I want to make the furniture safer and childproof, especially regarding sharp edges, stability, potential pinch points, and a child-friendly operation of the drawers and doors. I am interested in what specific measures or modifications you would recommend to make Malm furniture safe and durable for children. Experiences with suitable materials, tools, and techniques would also be very helpful. It is important to me that the furniture remains sturdy and visually appealing after the modifications, without sharp corners or hazardous handle areas. Thanks in advance for your tips and suggestions!
Dilen
31 Dec 2024 11:39
Hello tesau,
your question is very well posed, as safety with children’s furniture should really be a top priority. I would recommend approaching the individual steps systematically:
1. Analysis of critical points: Malm furniture is known for its sharp edges. Especially the outer corners and the inner edges of the drawers can quickly become painful. It is advisable to equip these corners with special edge protectors made of soft rubber or silicone.
2. Drawers and doors: For child safety, it is important that drawers and doors cannot be opened unintentionally. You could install magnetic or mechanical child safety locks that prevent children from fully opening them. There are also soft-close mechanisms that help prevent injury from accidental slamming.
3. Choice of materials and surface treatment: Also consider whether the surface is already child-safe (non-toxic finishes) or if you should seal it yourself. This increases durability and protects against scratches.
4. Stability: Especially with larger Malm dressers, you should check if they are properly anchored to the wall. Many IKEA pieces are prepared for this.
Do you plan to make the modifications yourself, or are you mainly looking for ready-made child safety products that are easy to install? Which Malm variants do you have exactly? I can then provide more specific advice.
Elijah42
31 Dec 2024 13:08
Child safety locks on drawers are important. Install edge protectors on the outside, preferably made of soft silicone. Furniture should always be secured to the wall. Additionally, equip drawers with cushioning foam to reduce the risk of pinching.
KAULIS
31 Dec 2024 14:46
As an additional note: For Malm furniture, proper wall anchoring is especially important because this furniture series can tip over if children pull on it. The IKEA assembly instructions usually include the appropriate wall plugs and screws.
For the edges, I recommend commercially available edge protectors, which have received very good ratings in safety tests. These are usually self-adhesive and relatively easy to install.
For the drawers, mechanical child safety locks can be helpful; these are often barely visible from the outside and therefore do not significantly affect the appearance. Make sure they can be operated with one hand to maintain everyday usability.
Kinbu
1 Jan 2025 09:27
Hello tesau,
Your topic is really important because children can quickly get to furniture and hurt themselves. If you are still at the beginning, I would recommend starting with a few simple and safe steps:
- Corner protectors can be found in many DIY stores, they are easy to install and provide immediate protection.
- To make drawers childproof, there are flexible locks that can often be attached without drilling, if you prefer not to make holes.
- Stability can be achieved by using additional wall anchors, especially for tall furniture.
If you like, I can send you links to products that I have used with my family. They helped us a lot. 🙂
Domau0
2 Jan 2025 15:03
tesau, if I understand your starting point correctly, you want to make Malm furniture more child-friendly and are looking for practical, safe solutions without completely changing the character of the furniture.
I would approach this systematically:
- Edges and corners: As already mentioned, I recommend custom-made soft edge profiles made of high-quality silicone, which you fix with a suitable child-safe adhesive. These profiles offer a certain degree of flexibility and are durable.
- Drawers: It’s worth trying to retrofit soft-close mechanisms if they are not already installed. On top of that, you can add magnetic locks that prevent children from accidentally opening the drawers.
- Safety stoppers: Use TÜV-certified child safety devices for the doors. There are versions that are easy to install and hardly noticeable visually.
- Wall anchoring: Not mandatory for Malm furniture but highly recommended. Best done with strong screws and wall plugs to ensure stability.
To assist you better based on your current situation, how large are the rooms and how many pieces of furniture do you want to modify exactly? The materials (e.g., solid wood vs. particleboard) also play a role in choosing the right protective measures.
