Hello everyone, I have an issue with my IKEA Malm drawers, specifically regarding their stability. After some time and frequent use, I notice that the drawers start to wobble and don’t slide as smoothly as they did in the beginning. The IKEA fittings seem to be reaching their limits, especially when the drawers carry a lot of weight.
My question is: How can I make Malm drawers more stable without completely rebuilding them or having to buy very expensive replacement parts? Are there simple modifications, better screws, additional reinforcements, or tricks that can improve their operation and durability? I would appreciate detailed tips, as I would like to use the drawers for a longer time. Thank you in advance!
Hey Lijola, this is exactly my area of interest!!! 🙂 Malm drawers are great, but yes, they can sag under heavy weight. I simply reinforced the sliding rails with stronger screws, which makes a big difference! I also attached small angle brackets at the bottom of the side panels to better support the weight and prevent wobbling. If you want, give this a try – it really works well! 🙂 Additionally, you might consider swapping the rollers for better, higher-quality ones that run more smoothly and steadily. You can do it, good luck!!!
Nathanaelk17 Apr 2023 11:47Hello Lijola, your approach is well thought out. To specifically improve the stability of the Malm drawers, I recommend the following steps: First, check the drawer slides – at IKEA, these are usually made from thin sheet steel with limited load capacity. Replacing them with more robust third-party slides featuring ball bearing technology can significantly enhance smoothness and durability. To reinforce the drawer box, you can install wooden support strips inside, about 12–15mm (0.5–0.6 inches) wide, placed along the sides and bottom to prevent warping. The reinforcements should be precisely fitted and not too thick to avoid affecting the function of the drawer slides. Using screws of grade 4.8 or 5.6 (instead of the usual 3.9) can also strengthen the connection between the drawer box and the slides. Finally, one note: check if your drawer slides have soft-close or damping systems – sometimes this requires a different approach to reinforcement to ensure everything continues to close smoothly. I would be interested to know if your drawers are already damaged or if this is just early wear? That way, I can tailor the advice better to your situation.
Peose schrieb:
Also, I screwed small angle brackets at the bottom of the side panels to better support the weight and prevent wobbling.That sounds like a really good idea, which I hadn’t considered before. I often find it frustrating when such simple furniture parts start to weaken over time, especially when you don’t want to make any complicated modifications.
Nathanaelk schrieb:
Using screws of grade 4.8 or 5.6 (instead of the usual 3.9) can also make the connection between the drawer box and the slides much more stable.This advice is very important too, because I often thought just tightening the screws would be enough, but the quality of the material really makes the crucial difference.
I’m currently working on similar projects and fully understand how frustrating it can be when supposedly simple furniture eventually gives way. So it’s definitely worth taking every small measure seriously. Good luck to everyone working on their Malm drawers! 🙂
