I am planning to use IKEA Metod drawers in the kitchen but want to make them childproof at the same time. My children are still small and very curious, so I want to prevent them from opening the drawers uncontrollably and taking out items that could be dangerous (e.g., sharp knives, cleaning products).
Are there any proven methods or products specifically recommended for securing Metod drawers safely without completely locking the drawers? It would also be helpful to know if certain types of child safety locks work better or worse with the Metod system in terms of installation and usability.
I would greatly appreciate any experiences and tips.
For the Metod drawers, you can use special child safety locks with magnetic catches. These are mounted inside and are not visible from the outside. This way, the drawer operates normally, but children cannot open it. Just make sure the lock is positioned correctly, otherwise it may get stuck.
Hey Emilbau,
sounds like a good plan to make the drawers childproof! You don’t want the little ones practicing their next magic tricks with the knife 😅.
I’ve had good experience with the magnetic locks from IKEA myself; they are practically invisible and don’t affect the look of the Metod fronts. A little tip: these locks require a matching magnetic key, which you keep on your keyring or nearby, otherwise it can quickly feel like you’re in a high-security area. 😉
If you want something less complicated, there are also clip-on child safety locks that can be installed without screws. However, they usually don’t hold as well against strong kids’ force.
Good luck with childproofing!
PeoDaniel18 Jun 2024 12:29Hello Emilbau,
Your question is very important because child safety in the kitchen is often underestimated. When it comes to IKEA Metod drawers, you should carefully consider the type of child safety locks you use.
First, the choice between internally mounted and externally attached locks is relevant. Internally mounted locks (such as magnetic locks) are usually the best option because they are invisible from the outside, hardly affect the appearance, and are difficult for children to bypass.
It is important to position the magnetic lock correctly so that the drawer does not catch when opening and the mechanism is not damaged. Note: some inexpensive systems can affect the drawer runners, so it is better to use high-quality locks.
Alternatively, some parents use so-called soft-close systems that prevent slamming, but these do not actually prevent the drawer from being opened and therefore do not ensure safety.
If you are not skilled in DIY, there are also complete child safety lock kits available for Metod that are easy to install.
If you have any further questions, I’m happy to help!
Emilbau schrieb:
Are there any proven methods or products specifically recommended for Metod drawers to securely lock them without completely blocking the drawers?Interesting question. I would first clarify what exactly is meant by "securely lock." Do you want to prevent children from opening the drawer entirely, or just create a minor obstacle to make access more difficult?
There are child safety locks that work well, but with younger or very clever children, they may eventually be bypassed. So this also depends on your children’s developmental stage.
Another aspect to consider is convenience: How often do you open the drawers as an adult? Some locks can make this quite challenging—maybe you wouldn’t want that permanently.
Also keep in mind the installation: Some attachments can damage the furniture or leave marks over time. This is relevant for Metod, as IKEA fronts are often thin.
In conclusion, I recommend carefully balancing safety, usability, and preservation of the furniture.
warrenka5720 Jun 2024 13:51I just wanted to share that a while ago I installed child safety measures myself, and choosing the right type of childproofing really helped reduce worries. My advice would be not only to secure the drawers but to take a more comprehensive approach:
- Install child locks on the inside (magnetic locks work well)
- Store dangerous items separately or in higher drawers
- Introduce children to the hazards in a playful way so they understand why certain things are off-limits
This worked well for us because the system relies not only on technology but also on knowledge and education. This takes a lot of pressure off parents to completely eliminate every risk.
Good luck with the process!
