Hello everyone, I recently started using the Ikea Metod kitchen fronts along with the matching drawers. However, I noticed that the drawers are quite loud when opening and closing, which can be disturbing, especially in an open-plan living kitchen area. My question is: how can I make the Ikea Metod drawers quieter without compromising their functionality or having to do major modifications? Are there proven techniques for sound dampening, better lubricants, or alternative installation methods that I could try? I have already considered softeners for the tracks but am not sure if that will be sufficient. Besides, it would be ideal if the solution is long-lasting and requires minimal maintenance. I look forward to any tips or experiences you can share!
Noise from Ikea Metod drawers is often caused by friction and impact against the cabinet frame. To make the drawers quieter, I recommend the following measures:
- Check drawer alignment: Ensure the drawers slide correctly and without binding, as misalignment increases noise.
- Apply suitable lubricants to the runners, such as silicone or PTFE sprays; these reduce friction without causing dirt buildup.
- Replace the original dampers with improved soft-close systems if not already installed, making sure they are compatible with Metod.
- Additionally, attach felt or foam rubber strips inside the drawer contact points; these absorb impact energy and reduce noise.
These methods can be implemented without major modifications and result in a noticeable reduction in noise.
RETRAVIS schrieb:
Application of suitable lubricants on the drawer runners, such as silicone or PTFE sprays; these reduce friction without causing dirt buildup.I can confirm this. To explore the topic in more detail, here is a brief guide to effective noise reduction for Metod drawers:
1. Remove the drawers: Pull the drawers out completely and lift them slightly to take them out.
2. Clean the runners: Thoroughly clean the runners with a dry cloth to remove dust and old residues.
3. Apply lubricant: Use a silicone-based or PTFE (Teflon) spray and apply it sparingly to the runners. It is important not to use oil, as it attracts dust.
4. Attach felt strips: Cut thin felt strips to size and carefully stick them onto the contact points between the drawer and the cabinet, especially on the sides where the wood might knock against each other.
5. Check soft-close dampers: If you don’t already have soft-close dampers, the retrofit kit from Ikea for Metod is recommended. These significantly cushion the impact and greatly reduce noise levels.
I have implemented these steps myself and was able to reduce the noise level of my kitchen drawers by more than half. Regular maintenance and clean installation are important to ensure long-lasting results.
Nofege schrieb:
Check soft-close dampers: If you don’t have soft-close dampers yet, the retrofit kit from Ikea for Metod is recommended.The retrofit kit is really the most effective solution. Otherwise, what you mentioned is enough: cleaning thoroughly, silicone spray, and felt strips. That’s it.
