ᐅ How can I make Ikea Metod cabinets more sturdy?
Created on: 6 Jun 2015 09:17
Mosigmar3
Mosigmar3
6 Jun 2015 09:17
Hello everyone, I am currently planning a major kitchen project using Ikea Metod cabinets and would like to improve the stability of these sometimes rather lightweight constructions. My question is quite specific: What methods or modifications do you know to make Metod cabinets more robust and permanently load-bearing, without losing flexibility and ease of assembly? For example, I am interested in any experiences with additional bracing, corner reinforcements, suitable fastening techniques, or alternative fixing materials beyond the standard components. Also, how is the load capacity when wall-mounting, and how can it be safely increased? I would greatly appreciate concrete tips, practical examples, or advice on material selection.
Leland
6 Jun 2015 09:43
I have always added additional horizontal wooden braces to my Metod cabinets, which noticeably increases their stability. When screwing into the back panel, it’s best not just to use wall plugs but to reinforce them with metal brackets. For wall mounting, it is important to rely on solid substructures and suitable anchors.
alvalo
6 Jun 2015 11:08
Hello Mosigmar3, your question is very comprehensive and important, as the standard Metod cabinets from Ikea are affordable and practical but do not always provide the best stability with frequent use or heavy loads. Here are a few suggestions that might help you:
- Reinforcing the cabinets with additional metal brackets inside the corners significantly increases load capacity, especially if you mount heavy appliances or worktops on them.
- A sturdy back panel is essential: if the back panel is only made of thin hardboard, you can replace it with a thicker plywood panel to improve stability.
- Pay close attention to the wall mounting: be sure to use suitable heavy-duty anchors and measure precisely where the wall cabinets will be hung.
- If possible, use metal profiles to connect multiple cabinets – this provides greater combined stability.
In my experience, combining these points achieves the best balance between effort and stability.
noge58
6 Jun 2015 13:26
Great topic, I’m totally on board! 🙂 I’ve added reinforcements myself and can only recommend not saving on screws and fasteners! Plus: Use small metal brackets on the inside corners, they really make a huge difference! Especially if you have children or often move things around, this greatly increases safety! So: Grab your screwdriver – your Metod cabinet will feel much more stable afterward. Go for it!
Tarbi
7 Jun 2015 08:54
alvalo schrieb:
Pay close attention to the wall mounting: Be sure to use suitable heavy-duty anchors and measure precisely where the wall cabinets will be hung.
This is a crucial point that I would like to expand on: The wall itself is often underestimated as a factor. For example, drywall (plasterboard) walls do not support heavy-duty fastenings without special measures. The only options here are to either attach the cabinets directly to the underlying framework (e.g. wooden studs) or use a screwed mounting rail to distribute the load. Simply using more or larger anchors is not always the solution. I would even say that the stability of the wall must be ensured first before considering reinforcements on the cabinets themselves.
Mosigmar3
7 Jun 2015 12:31
You bring up an important point, Tarbi. My wall is actually an older brick wall – so solid masonry construction. In that case, can I rely on standard heavy-duty anchors for mounting, or are there special recommendations to increase the load capacity when hanging multiple cabinets? How does this affect the total weight of the cabinets, for example?
