ᐅ How can I make IKEA Brimnes furniture more stable for long-term use?
Created on: 16 Jul 2018 08:37
isaiah0
Hello everyone, I have been using the IKEA Brimnes furniture series for some time now, mainly dressers and shelves, and I am wondering: how can I make IKEA Brimnes furniture more stable for long-term use? The furniture is affordable and functional, but with heavier loads and after several years, it often starts to wobble or the joints become loose. I would like to know which practical measures are effective to significantly improve stability without compromising the furniture’s charm. Are there any proven reinforcements, screw techniques, or additional materials that are worthwhile? Thanks in advance for your tips and experiences!
giabau
17 Jul 2018 07:09
Hello isaiah0, I’m happy to share some practical tips with you:
1. Replacing the back panel on the Brimnes:
- The back panel is usually only nailed or stapled in place, so it can be removed without much trouble. Carefully pry it off using a flat chisel or a wide screwdriver.
- Important: The material thickness should be about 3–4 mm (0.1–0.15 inches) plywood; thicker makes installation more difficult, thinner doesn’t provide enough stability.
2. Fastening:
- Use small screws or multi-purpose nails to secure it – these have the advantage of being easy to remove if needed.
- If you use screws, be sure to pre-drill to avoid splitting the plywood.
3. Fit:
- Cut the plywood preferably with a fine-tooth saw or a jigsaw.
- Cut it slightly smaller than the original back panel opening to allow for fitting tolerances.
4. Additional tip:
- If the back panel sits slightly recessed or loose during installation, it’s helpful to use small spacers or shims to prevent the panel from warping.
With this approach, you can significantly improve stability by using a solid back panel without weakening the furniture structure.
NUPIN
17 Jul 2018 09:57
Hey, I just wanted to say: Reinforcing the back panel with plywood was a real game changer for me! 🙂 I did this years ago, and since then the dresser has been completely stable, no more wobbling. Additionally, I installed 5x5cm (2x2 inch) metal brackets in the corners, which are hardly visible from the inside. Just give it a try, it’s definitely worth it!
lechen
18 Jul 2018 11:02
isaiah0 schrieb:
Are the furniture pieces designed so that you can easily remove the back panel and replace it with your own plywood board without destabilizing the entire structure?
Yes, that is usually possible. The back panels are typically only nailed in. Remove the panel, insert a suitable board, and secure it with screws or nails. Don’t forget to reinforce the corners.
keosau9
18 Jul 2018 17:33
Important: The furniture should stand completely level. Even slight wobbling increases elasticity and loosens screws. Compensate for floor unevenness with suitable washers or adjustable feet.
