Lisamadou9 Nov 2020 08:43I have several Ikea Brimnes furniture pieces in my apartment, including dressers and cabinets. Since small children spend a lot of time here, I want to make this furniture childproof. In my opinion, the width of the Brimnes furniture and its rather simple design offer good opportunities for securing it, but I lack the necessary expertise to know which methods and products are truly effective without damaging the furniture or making it impractical.
Therefore, my question is: How can I childproof Ikea Brimnes furniture so that it cannot tip over, there is no risk from accessible drawers for toddlers, and small fingers are protected from injuries caused by corners and edges? I am especially interested in recommendations for anti-tip devices, locks, or padding that might fit well, as well as advice on correct installation.
Who has had good experiences or knows practical solutions? Which accessories are recommended and what should definitely be avoided? Thanks for your tips!
To secure Ikea Brimnes furniture, I recommend the following measures:
- Tip-over protection: Brimnes furniture is often tall with a narrow base – installing tip-over restraints that attach the furniture to the wall with brackets is strongly advised. Make sure the screws are anchored directly into the solid wall, not just drywall.
- Drawer locks: Child safety locks with a latch mechanism that mount inside the drawers work well. There are special drawer locks that are hardly visible and leave no marks on the furniture.
- Corner and edge protection: Soft silicone corner protectors can be attached to the visible edges. These are flexible and cushion impacts.
Assembly should be done with appropriate tools and some DIY skills, as poorly installed tip-over restraints can cause more damage.
Thank you for the very clear and helpful summary, Dopoki!
I also experienced similar concerns at home, especially when the little ones start trying to scoop things up and climb on their own. It’s completely understandable that you want to protect the furniture more thoroughly.
One thing that was very important for me was installing soft-close mechanisms that allow drawers and doors to close quietly and safely. This eliminates the risk of fingers getting pinched when children are playing around the cabinets.
Not all IKEA models come with this feature as standard, but I retrofitted these mechanisms myself – it gives me much more peace of mind in everyday life. Maybe this could be a useful option for you as well?
Good thread, I’d like to go into more detail because the Brimnes series has some specific construction features that need to be considered for child safety:
- Material and joints: Brimnes furniture is mostly made of pressed wood with veneer. The thin edges are prone to damage when drilling, so you need to be very careful with anti-tip devices. It’s better to screw into the joints or directly into the wall behind.
- Wall mounting: Since children often climb on cabinets, they apply significant force. Anti-tip fittings should be anchored into the wall, not just attached to the furniture frame. For drywall, adding a wooden block inside can be helpful to provide a solid anchor for durable wall plugs.
- Drawer locks: Some child safety locks completely block drawers, which can be inconvenient for daily use. Systems that use magnets or pressure mechanisms, which adults can operate easily, are recommended.
- Edge protection: Besides protecting external corners, self-adhesive foam pads are useful; they are transparent and almost invisible. These especially protect knuckles during quick movements.
By the way, I’m curious: which type of furniture do you have specifically? Dressers only, wardrobes, or also beds? This greatly influences the best safety measures to take.
Lisamadou9 Nov 2020 13:02lorena schrieb:
By the way, I’m curious: Which specific type of furniture do you have? Just dressers, wardrobes, or also beds? That greatly affects the best safety measures.Thanks for asking, lorena, that’s an important point for me. I mainly have the Brimnes dresser with drawers (the 6-drawer version) and also the 3-door wardrobe. I especially want to secure the wardrobe against tipping, as stability is the main focus.
In addition, I want to childproof the dresser to prevent the drawers from being pulled open by the kids. I don’t have the beds (yet), so for now it’s only about the wardrobe and dresser. If I come across new insights, I’m happy to update.
Regarding the specific furniture, here are some recommendations for the Brimnes chest of drawers and wardrobe:
- Anti-tip protection: Use brackets or anti-tip sets that are securely anchored to the wall with strong screws. Most sets include two attachment points, fixed to the upper furniture frame and mounted on the wall. It is especially important to identify the wall type (concrete, brick, drywall) before installation and use appropriate wall anchors.
- Drawer locks: I recommend flexible, internally installed pin locks. Some parents have had very positive experiences with magnetic wardrobe locks. These are discreet and hardly affect the aesthetic appearance.
- Edge protection: Apply self-adhesive corner protectors on the front edges. These are usually available in transparent or neutral white. They significantly reduce the risk of injuries for small children.
- Installation note: After assembly, carefully test each safety device for load capacity. Locks must withstand pulling or climbing forces.
With these measures, your Brimnes furniture should be much safer for children.
