Hello everyone, I own several Ikea Brimnes cabinets where the doors unfortunately close quite loudly and with a rattling noise. This is especially annoying when the cabinets are left open in the evening and you want to close them quietly without the slam disturbing the room.
My specific question is: How can I modify the doors of these Brimnes cabinets, or which methods and materials can I use to make them close particularly quietly? I’m not just looking to avoid the loud bang, but also to achieve a dampened, gentle closing.
I’ve already considered the usual dampers and soft-close mechanisms, but which solutions actually work well with Brimnes? Are self-adhesive dampers on the inside of the door a good option? Or is it better to replace the hinges?
I would really appreciate any tips and practical experiences you can share.
Hello Deonau62, your question is very detailed, which is great.
Regarding the topic: you can use special self-adhesive soft-close bumpers that are applied to the inside of the door or the cabinet frame. These help achieve a delayed, quiet closing.
In addition, there are replacement hinges with built-in damping systems that greatly improve this effect and are more durable.
It is also important that the doors are properly adjusted: if they do not close flush, loud impact noises will occur. This should be the first thing you check.
Loud cabinet doors always annoy me as well, especially late in the evening.
I can understand that perspective. Sometimes you just want a simple, non-technical solution. That’s why I tried felt and foam pads; they definitely soften the noise—without the need for expensive hinge replacements.
However, if someone is aiming for perfection, soft-close hinges are definitely the best option.
karlau schrieb:
I sometimes think all those soft-close mechanisms are a bit over the top.
Here are some facts about Ikea Brimnes cabinets and quiet door-closing mechanisms:
- Standard Brimnes hinges do not have soft-close features and make noise when doors slam shut.
- Self-adhesive silicone or rubber dampers reduce noise, are cost-effective, and easy to install.
- Soft-close hinges offer a more professional solution but require more installation effort.
- Proper door adjustment is essential, as loose or incorrectly aligned doors significantly increase noise.
My advice: First, adjust the doors correctly, then add dampers or replace hinges if needed.
Response to Deonau62:
If you want a very gentle closing without upgrading technically, I recommend as a simple solution using thin felt strips or silicone bumpers on the inside of the door near the contact point.
This can already significantly reduce the impact and is quick to apply. If that is not enough, the next logical step is to replace the hinges with soft-close ones.
Regarding the topic of "quiet Brimnes wardrobe doors," I would also recommend experimenting a bit: For me, attaching dampers at different points on the inside of the door helped.
Sometimes just a small amount is enough to noticeably reduce the noise. And if you like the effect, you might consider replacing the hinges.
After all, you don’t want to take apart half the wardrobe just for a small improvement.
