ᐅ How can I make IKEA BESTA weather-resistant for use on a balcony?
Created on: 3 May 2024 14:37
Grace30Hello everyone,
I am considering using my IKEA Besta cabinet on the balcony, but I definitely want to make it weather-resistant so that wind, rain, and UV rays affect it as little as possible. I know that the Besta is primarily designed for indoor use, but I find the furniture very practical because of its modular system and size.
Does anyone have experience or tips on how to modify or treat the Besta for outdoor balcony use so that the material (especially the wood-based panels and edges) is well protected? What types of paints, sealants, or other measures are recommended? Are there any practical tips for installation or additional protective measures?
I look forward to your informed suggestions, as I have already read quite a bit but encountered many contradictory statements. Thank you!
Grace30 schrieb:
Does anyone have experience or tips on how to modify or treat the BESTA for balcony use so that the material (especially the wood-based panels and edges) is well protected?The IKEA BESTA is not designed for outdoor use, and the wood-based panels are highly sensitive to moisture. A practical approach includes:
- Sealing all edges and surfaces with a high-quality acrylic paint or a two-component clear coat suitable for outdoor use. Apply multiple layers and allow them to dry thoroughly.
- Special wood preservatives with UV protection are also recommended to help prevent the material from becoming brittle.
- For the inside surfaces of the carcasses, water-repellent impregnations can be used.
- The cabinet should be positioned to avoid direct exposure to rain as much as possible (e.g., under a roof overhang).
- Raising the feet or placing supports underneath helps prevent water from pooling at the bottom.
These measures significantly extend the lifespan; however, there is still some risk of swelling or warping if maintenance is neglected.
I’ll add a step-by-step guide:
- Clean and degrease all surfaces to be treated using alcohol or a mild cleaner.
- Roughen edges with fine sandpaper (grit 220) to improve paint adhesion.
- Apply at least two to three protective coats of paint using a brush or roller, sanding lightly between coats with sandpaper (grit 320).
- For wooden edges, additionally apply a water-repellent impregnating oil to minimize moisture penetration into the particleboard.
- Line the back panel and base cabinet with an additional foil or water-repellent membrane to reduce vapor diffusion.
- Check screws and metal fittings; replace with rust-resistant ones if necessary.
Question for you: How is your balcony oriented? Is it exposed to strong wind or direct rain? Ambient temperature also plays a role in maintenance.
kaubi schrieb:
Question for you: What direction does your balcony face? Is it exposed to strong wind or direct rain? My balcony faces southwest, is partially covered, but open on the sides. Rain often comes in sideways when it’s windy. Direct sunlight regularly hits it in the afternoon and early evening.
Thank you for the detailed explanation, the steps are very helpful. I’m comfortable with sanding and painting. Is there anything to consider when choosing the paint regarding UV resistance? And what about the legs or base supports? Should they be specially protected or designed differently?
Regarding your question about paint choice: UV resistance is very important for outdoor furniture, otherwise the surface will fade and become brittle quickly.
- I recommend a two-component polyurethane (PU) paint or a polyurethane-based acrylic paint with explicit UV protection.
- These paints are especially resistant to water, abrasion, and sunlight exposure.
Regarding the feet: It is ideal to place the BESTA units on small rubber pads or plastic glides to prevent moisture from reaching the wood from below. This is particularly important if the balcony floor retains moisture.
It might also be worth installing a water-repellent underlay or a wooden frame that raises the cabinet and allows for air circulation.
andre3 schrieb:
These measures significantly extend the lifespan, but there is still some risk of swelling or warping if maintenance is neglected.This leads me to the question: Is the effort really worth it when the BESTA is not actually designed for outdoor use? Why not just choose outdoor furniture that is specifically made for that purpose?
I think many people are trying to force a solution that only works moderately well and ends up being frustrating. Sure, customization is tempting, but when it comes to weather exposure, you shouldn’t cut corners. Alternatives are often more durable, sustainable, and less stressful in the long run.
Just my provocative opinion. Looking forward to hearing what you think!
