ᐅ How can I make BILLY doors truly childproof and sturdy?
Created on: 29 Jun 2022 14:23
heinrichdu
heinrichdu
29 Jun 2022 14:23
Hello everyone, I have a question regarding safety for IKEA BILLY shelves: How can I make the doors of these BILLY units truly childproof and at the same time stable, so they can withstand small children without the doors frequently becoming loose or warped from regular use? My main concern is not only that the doors are locked but also mechanically secured in a way that makes them really difficult to open and prevents them from being easily forced open, while still not being too stiff or unnecessarily complicated for adults. What tips or practical solutions have you seen or implemented to permanently childproof and securely fix BILLY doors? There are many different approaches—from additional screws and child safety locks to special hinges or reinforcements. I look forward to hearing about your experiences and suggestions!
praWarre69
29 Jun 2022 15:02
Hey heinrichdu, great question! 🙂 I have two little whirlwinds at home myself and totally understand your concern – BILLY isn’t exactly known for being childproof. What worked really well for us are so-called "magnetic child safety locks." They are completely invisible from the outside, and inside there’s a magnet that you use to open the doors. For the kids, it’s almost like magic because the regular handle doesn’t work, yet the doors still latch securely and close firmly. The nice thing is: there’s no additional stress on the hinges, so the doors don’t warp as easily. Sure, it might take a bit of patience for adults to get used to, but a little practice makes it easier :-)
heinrichdu schrieb:
How can I make the doors of these BILLY shelves truly childproof and at the same time stable
Also, you should make sure the shelves themselves are properly secured to the wall. Even the sturdiest door won’t help much if the whole unit tips over when the kids pull on it. A little tip from me: invest in wall mounting for BILLY right away; it makes everything much more stable!
MUMENAR
29 Jun 2022 17:44
I would approach this topic with caution and not focus solely on "child safety locks," but also consider the construction itself. BILLY shelves are basically designed to be easy to operate – this also applies to the doors. Any additional reinforcement with screws or braces may provide a short-term fix but can easily cause problems with the hinges and potentially lead to warping, which could negatively affect the overall durability of the doors.
praWarre69 schrieb:
Magnetic child locks [...] are completely invisible from the outside
That certainly has its advantages, but I wonder if it also increases the time required for adults to open them, which could become a problem in urgent situations.
My suggestion would be to consider alternative doors – for example, lockable versions with a reliable locking mechanism – or to replace them with more robust interior doors from other furniture manufacturers. Relying solely on a mechanical lock on the BILLY system without addressing the material weaknesses and construction design, in my opinion, is a half-measure solution.
Of course, this involves more effort, but if the goal is to provide lasting protection for small children, I believe it is necessary to address the issue more fundamentally rather than just improving the handle.
V
vincent46
29 Jun 2022 19:36
I would like to take a somewhat more empathetic approach here. I understand how important child safety is and how frustrating it can be to constantly make adjustments every few days or to always worry that the doors won’t hold.
MUMENAR schrieb:
BILLY shelves are basically designed to be easy to use
That is certainly true, and it is always a balancing act between childproofing and everyday usability for the whole family. I would recommend using solutions that the child can eventually understand, such as magnetic locks, as described by praWarre69. It is also important that the doors are securely and permanently fastened.
If the doors of the BILLY shelves seem too thin or somewhat unstable, you can reinforce them from the inside with thin metal brackets to increase stability. However, this requires a proper installation with screws tightened firmly, since otherwise children often use these points as handholds.
Sometimes it also helps to place the shelf lower and thus out of the direct reach of little ones. Of course, this is not always possible, but if it is, no expensive locking mechanism is necessary.
The best approach is probably to combine different methods rather than relying on just one solution, so that it remains both child-safe and stable.
bauku
30 Jun 2022 08:55
Hi, I’d like to share my experience – a combination of several tricks worked really well for us:
1. Magnetic child safety locks for BILLY doors, as suggested by praWarre69 – absolutely brilliant, we use them too and haven’t worried since! 🙂
2. We also added small metal reinforcements to the inside of the door frames. This made the doors noticeably more stable and prevents them from twisting or wobbling when pulled.
3. Additionally, we installed soft-close hinges, available at IKEA or other hardware stores. They stop the doors from slamming shut and extend their durability.
I know it’s a bit of extra effort, but the results are great. Our little ones can still open the doors, but only with a bit of trickery, and you really get the feeling that nothing becomes unstable or gets damaged.
So: it’s not just one thing, but the whole package! Don’t get discouraged, it’s definitely worth it :-)
heinrichdu schrieb:
How can I make the doors of these BILLY shelves truly child-safe and stable at the same time
