ᐅ How can I increase the load capacity of IKEA BESTA furniture?
Created on: 13 Mar 2018 09:23
Eliah8
Eliah8
13 Mar 2018 09:23
Hello everyone, I have a somewhat specific question regarding the load capacity of IKEA Besta furniture. Specifically, I’m interested in how I can reinforce my BESTA cabinets or shelves so they can carry significantly more weight without compromising or breaking the underlying structure. I have already noticed that the original panels and frame have certain limitations, but I want to know if it’s worthwhile to add extra reinforcements, which technical options are both practical and effective, and which materials would be best suited for this. I’m interested in both the static load capacity of the shelves themselves and the overall construction in terms of stability against sagging or wobbling. Perhaps there are also experiences with modifications or conversions that I should be aware of to avoid reducing functionality. Thanks in advance for your tips!
FIKAPU
13 Mar 2018 09:47
Eliah8 schrieb:
how I can reinforce my BESTA cabinets or shelves so that they can carry significantly more weight
The most effective way is to reinforce the back panel or replace it entirely with a 6-8 mm (1/4–5/16 inch) plywood sheet. Additionally, sturdy corner brackets and extra center supports under the shelves help significantly.
Katau
13 Mar 2018 10:36
Eliah8 schrieb:
I am interested both in the static load capacity of the shelves themselves and the overall construction in terms of stability against bending or wobbling.
Hello Eliah8,
I can relate to your question, as IKEA BESTA furniture is designed for a certain standard weight, but many people use it well beyond that. To significantly increase the load capacity, several points are important:
- The shelves themselves: Avoid standard particleboard or MDF and instead use plywood or laminated birch panels. These materials are much more resistant to bending.
- Reinforcement of the structure: As FIKAPU mentioned, a solid back panel is essential – ideally a continuous, sturdy board rather than a lightweight hardboard. Alternatively, metal brackets or custom-made metal frames can be installed on the inside.
- Additional supports or center rails beneath the shelves help distribute the load more evenly and effectively reduce bending.
- Connection points: Screws and dowels can fail under high loads. They can be replaced with longer screws or supplemented with wood glue. Sometimes, adding extra screw holes to strengthen the joints also helps improve structural integrity.
It is important during modifications to respect the original construction so that you don’t inadvertently reduce the load-bearing capacity elsewhere. A precise assembly where everything fits firmly and does not wobble is ultimately crucial.
I hope this helps you for now!
Demetrius
14 Mar 2018 08:12
FIKAPU schrieb:
The most effective method is to reinforce the back panel or completely replace it with a 6-8 mm (1/4–5/16 inch) multiplex plywood sheet.
I think that's a very good tip. I once tried to increase the weight capacity of my BESTA furniture myself because I needed to store quite a bit of tech equipment and books. Supporting the shelves in the middle with additional wooden beams also helped me a lot – this noticeably reduced the sagging.
Katau schrieb:
The connection points: screws and dowels can fail under heavy load.
I can confirm that. I recently experienced a shelf becoming unstable due to a loose screw. Since then, I regularly check the screws and reinforce them with wood glue if necessary.
I also think it’s important not to rely on just one single measure, but rather combine several small improvements. This way, the furniture ultimately feels more secure while still looking good.
I’m curious if anyone has experience with metal frames or similar inserts integrated directly into the IKEA construction? So far, I’ve been hesitant because I find it challenging to find the right dimensions and fixings without spoiling the furniture’s appearance.
