Hello everyone, I am planning to install interior lighting in my Ikea Pax wardrobe because it is often difficult to find individual clothing items in low light. My question is: What options are available specifically for lighting the inside of an Ikea Pax that are both technically simple and visually unobtrusive? I have already read about LED strips, battery-powered lights, and magnetic lights, but I am unsure which solution is durable and can be integrated well without major modifications. Could you also provide advice on power supply, installation, and possible control options such as motion sensors or switches? Thank you in advance for your tips!
kasan schrieb:
Aren’t these motion detectors often too sensitive or do they respond with a delay?That can happen, yes. But modern PIR sensors are quite good at detecting real movement only. Sometimes it’s due to the installation—if the sensor is positioned incorrectly, you’ll have to switch it off manually more often or it will turn on unnecessarily frequently.
kasan schrieb:
I’m therefore interested in which alternatives are more cost-effective and reliable in the long runIn the long run, I find 12V LED strips with a power supply unbeatable in terms of cost and lifespan. And if you do a bit of DIY, you can even add an automatic shut-off function, so nothing is lit unnecessarily. This saves energy and extends the life of the LEDs.
Battery-operated lights are great for rental apartments, of course. But eventually, it gets annoying when you have to keep replacing batteries.
Conclusion: For a very simple and clean solution, use a flexible LED kit, pay attention to cable management, and install a motion detector with a delay timer. Then you’re almost there 😊
foneo59 schrieb:
If you want to take a closer look: What exact Pax type do you have (width, height, interior layout)?Because this is essential for planning: Without exact dimensions and interior layout, it is difficult to offer an optimal lighting solution. For example, if you have shelves, you might need light strips for each shelf level.
The type of door (sliding door or hinged door) also affects the sensor mounting locations.
A technical tip: Pay attention to the power supply’s output current (amps). A power supply that is too weak can cause flickering or reduce the LEDs’ lifespan. Depending on the length of the LED strip, you should plan for at least 1 amp per meter of LED strip.
Also: If the cable is routed behind the side panel, be sure to check the strain relief to prevent loose connections. Cable ducts or braided sleeves can help here.
Otherwise: Feel free to share some details, and we can provide more specific advice.
