ᐅ How can I level IKEA PLATSA furniture on an uneven floor?
Created on: 14 Mar 2024 08:32
rikke
rikke
14 Mar 2024 08:32
Hello everyone, I have the following problem: I want to place my IKEA Platsa furniture on a floor that is not completely even – there are slight irregularities that are barely visible to the naked eye, but the furniture ends up being crooked and wobbly. My question is: How can I level the Platsa furniture on an uneven floor so that it stands straight and stable without compromising the appearance or functionality? Are there any proven methods or special accessories from IKEA or third-party suppliers that are suitable for this? I would appreciate any tips, as it is important to me that the furniture stands securely and that the doors or drawers operate properly.
nojaus
14 Mar 2024 09:18
rikke schrieb:
I want to place my IKEA PLATSA furniture on a floor that is not completely level – there are slight unevennesses that are barely visible to the naked eye, but as a result, the furniture stands crooked and wobbles.
I know that feeling all too well; it’s really frustrating—especially when you’ve just assembled the furniture and it doesn’t sit properly. I personally attached some thin felt pads under the feet to compensate for minor unevenness. But depending on how uneven the floor is, that’s not always enough.
It might help to know exactly how pronounced the unevenness is in your case. Sometimes adjustable furniture feet or small wooden shims can help, but you need to be careful to avoid compromising stability.
BOMILAN
14 Mar 2024 10:02
Use adjustable furniture feet from third-party suppliers.
Use wooden wedges or shims to bridge gaps.
Attach leveling pads that can be cut to size.
Unfortunately, IKEA does not offer suitable feet specifically designed for uneven floors.
Dilen
14 Mar 2024 11:27
Precise leveling on uneven floors requires a systematic approach.
1. First, use an accurate spirit level to identify exactly where the biggest unevenness is. A small digital level or a laser level is often sufficient for greater precision.
2. Since IKEA PLATSA modules have a screw foot system, their height cannot be adjusted, which complicates the process.
3. Alternatively, you can either:
- Cut wooden wedges from a hardware store to the appropriate thickness and place them under the furniture feet.
- Try leveling pads or felt gliders of different thicknesses to prevent the furniture from wobbling.
4. It is important to secure the wedges or pads well so they do not slip— for example, with double-sided tape or a small screw (if possible). Otherwise, the furniture will be unstable.
5. Even better: If you are handy, you can retrofit height-adjustable furniture feet. In the furniture profile category, it is often possible to create or use a hole to install screw feet.
6. Finally, I recommend testing doors and drawers after leveling, as alignment can also affect the functionality of the fittings.
Could you perhaps provide more details about the floor covering and the height of the unevenness? That would allow for more targeted advice.
andre3
14 Mar 2024 13:44
Dilen schrieb:
IKEA PLATSA modules feature a screw foot system, but unfortunately these feet are not height-adjustable
That is correct; the PLATSA modules do not come with height-adjustable feet by default.
The most effective solutions are:
- Placing wooden or plastic shims under the feet to compensate for minor height differences.
- Purchasing adjustable leveling pads that can be cut to size.
- For larger unevenness, a professional might retrofit the feet with height-adjustable screws.
It is important to ensure stability: loosely inserted shims can increase the risk of tipping. If possible, the furniture should also be secured to the wall, especially with PLATSA systems, to provide additional safety.
rikke
15 Mar 2024 08:05
andre3 schrieb:
If possible, the furniture should also be fixed to the wall, especially with PLATSA systems, to ensure extra safety.
Thank you for this tip, I will definitely keep it in mind. The floor is vinyl, with slight variations of about 5 mm to 7 mm (0.2 to 0.3 inches).
That sounds like wedges could be a practical solution. However, I wonder if there are special products available that are visually unobtrusive and still load-bearing? I’m concerned that visible wedges might make the furniture look somewhat “fragile.”
Maybe there are also professional adhesives or pads that can secure the furniture firmly without having to resort to wooden blocks?
