ᐅ How can I integrate additional power outlets into IKEA Besta units?
Created on: 10 Jun 2022 14:37
Garritbe
I am planning to add extra power outlets to my IKEA Besta sideboard to better supply my media devices. The outlets should be integrated as discreetly as possible without compromising the stability or appearance of the furniture. I am also interested in how to organize the wiring to avoid cable clutter behind the sideboard and how to make good use of any available interior space. What solutions have you already implemented or can recommend for this? Are there specific power strips or inserts suitable for installation in an IKEA Besta? I would appreciate any tips on installation, fitting, and cable management!
roryvin
12 Jun 2022 08:43
FeAndreas1 schrieb:
As an alternative, you can also use "furniture power outlets" (e.g., from manufacturers like Brennenstuhl or Bachmann), which are specifically designed for furniture installation.
These built-in power outlets are indeed a very practical solution. Important factors when choosing them include:
- Installation size and depth matching the furniture unit
- Compliance with safety standards (e.g., IP44 protection or higher, depending on the application)
- Safety features such as child protection and surge protection
- The ability to switch the outlets on and off via a switch
Additionally, it is important to ensure that the power strips remain modular, allowing you to replace the strip in case of a defect or when changing the furniture.
Another tip: If a fixed electrical supply inside the furniture is planned, it is advisable to install a protection contact junction box with a residual current device (RCD). This can enhance electrical safety in the house.
Ethan
12 Jun 2022 11:29
Garritbe schrieb:
That sounds practical! However, I want to avoid having visible cables from the outside. Ideally, they should remain invisible or at least discreet.
Here is a simple tip:
- Use cable grommets (cable pass-throughs) at the back panel or in the base of the inside of the Besta unit to route cables out of sight.
- Inside, attach power strips with double-sided tape or screws.
- When positioning the power strips, placing them behind drawers or doors helps keep them hidden from view.
Additionally, flat, flexible cables are advantageous so the furniture can close flush even with the door shut.
Another option is using cordless power outlets with batteries or power banks if you want to avoid cables altogether, though this is more of a special case.
