chenalba351 Apr 2024 09:13Hello everyone,
I am planning to install custom interior lighting in my IKEA Pax wardrobe. I am particularly interested in different options to achieve even, functional, and pleasant lighting. I have already considered LED strips and small spotlights, but I am unsure how to practically manage the wiring without damaging the wardrobe or affecting its appearance.
Additionally, I would like to know if motion sensors can be integrated well and what type of power supply is recommended (e.g., mains power via socket or battery solutions). If anyone has experience with specific technology or clever DIY solutions, I would greatly appreciate detailed tips and recommendations.
How can I illuminate the interior of the Pax wardrobe individually so that it looks aesthetically pleasing and is practical for everyday use?
Thank you in advance!
Hello chenalba35,
your question about custom lighting for the Pax wardrobe covers many aspects, but I’ll try to summarize the key points:
- LED strips are ideal for evenly lighting interior surfaces. They can be easily attached with double-sided tape.
- It’s important to choose flexible, well-dimmable LEDs so you can adjust the brightness.
- For power supply: a power adapter with a wall outlet connection is more reliable, while batteries are convenient if there is no nearby outlet but usually don’t last very long.
- Motion sensors can be easily installed between the cable and the light switch. Many sets even come with sensors included.
- Make sure to route cables discreetly, for example behind side panels or along rails.
If you have further questions about specific products or wiring, feel free to ask – I’m happy to help!
Hello chenalba35,
I’d like to add some more technical details to gregto’s advice since you’re asking for specific options and practical implementation tips.
First, regarding the choice of lighting: LED strips are really the most flexible option and offer a wide variety (white, warm white, also RGB). Make sure they are dimmable and have a low profile. Ideally, choose ones with 12-volt DC (direct current) power, as this is safer and easier to handle.
For the wiring, I would proceed as follows:
- Before installation, measure the cabinet completely and mark where the LED strips should be placed.
- Use flat extension cables and connectors. These allow you to connect individual segments or test them temporarily.
- Most LED strips come with a power supply unit that you place behind or beside the cabinet. Ideally, hide the power supply in an upper corner.
Motion sensors can be integrated easily; the best are those with adjustable switch-on time and sensitivity. They often use a micro-infrared sensor that detects movement up to about 1.5 meters (5 feet).
If battery power is an option for you, pay attention to the capacity (mAh) and whether the battery can be powered during charging (allowing continuous use).
Feel free to ask if you want details on switch integration or recommendations for LED brands.
Regarding the topic "How can I customize the interior lighting of the Pax?", I recommend a pragmatic approach focused on materials and costs.
- Preferably use 12V LED strips with warm white light to ensure eye comfort.
- Use connectors and prefabricated cables to avoid patchwork and keep the installation reversible.
- Motion sensors with integrated timers are often available as complete solutions nowadays and are reliable enough in almost 100% of cases.
- For power supply, I consider mains operation the most practical. Batteries are inconvenient in the long run since they need regular charging.
The effort and investment should be balanced reasonably against the benefit. Professional products guarantee long-lasting operation and functional safety.
If the focus is on DIY, I consider LED strips with wire extensions, connectors, and power supplies the best combination.
Franck schrieb:
Motion sensors work very well with 12V systems.That’s true, but I would add that not every motion sensor responds equally well. Some models only switch on or off after a noticeable delay. For quick response times, you need higher-quality sensors with the appropriate detection range.
Also: How is the lighting situation for different interior areas in your Pax? Is a central LED strip and one sensor enough for you, or do you want to illuminate individual compartments separately? This significantly affects the complexity and technical design.
Otherwise, I agree that mains power is more efficient, but modern battery technology is also worth considering—depending on the installation location and usage.
