ᐅ How can I improve the stability of Malm bedside tables?
Created on: 11 May 2023 20:03
Keke65
Keke65
11 May 2023 20:03
I recently bought Malm nightstands from IKEA, and although they look very nice, I’ve noticed that their stability isn’t ideal. Especially when I place heavier items on them or bump them lightly, they wobble noticeably. My specific question is: What options are there to improve the stability of Malm nightstands without significantly changing their appearance? I was thinking, for example, of adding extra braces or other fixing methods. What experiences have you had with this? Thank you in advance for your tips!
sanjon
11 May 2023 20:25
Hi, I would recommend reinforcing the angle brackets on the inside or adding additional metal brackets. This stabilizes the structure with minimal effort and remains visually unobtrusive.
bapar
11 May 2023 21:07
Hello Keke65,
To effectively improve the stability of Malm nightstands, I would first recommend analyzing their weak points. In these tables, the joints between the side panels and the top and bottom boards are often the most critical, as they are mainly held together with dowels and screws. I suggest the following steps:
1. Check all screws for tightness and retighten if necessary.
2. Install metal corner brackets on the inside corners – preferably ones specifically designed for furniture construction (e.g., 30x30 mm (1.2x1.2 inches)). Make sure the brackets do not penetrate through the panels.
3. Additionally, consider adding longitudinal braces or a thin wooden panel on the back if one is not already installed. This will significantly reduce lateral wobbling.
4. If you have good DIY skills, you can also apply wood glue to all joints and clamp them well until fully cured.
Could you please clarify whether your nightstand still has the original back panel or if it is missing? This is important, as the back panel contributes significantly to the overall stability.
Keke65
11 May 2023 21:35
bapar schrieb:
Could you maybe clarify whether your nightstand already has the original back panel installed or if it is missing?
Yes, the back panel is still attached, so it’s complete as delivered by the manufacturer. Do you perhaps have a recommendation for those metal brackets? I’d like to install them as discreetly as possible since the nightstand is in the bedroom and I don’t want steel elements to affect the overall appearance.
Giagau
12 May 2023 07:18
The stability of furniture pieces like the Malm bedside table can often be significantly improved with small, targeted measures without affecting the appearance. For Ikea furniture, flat, galvanized steel brackets are most suitable, which can be mounted on the inside edges. Alternatively, so-called "corner braces" are an option; these are relatively small and can be attached with short screws. Please make sure to use screws that are not too long to avoid piercing through to the exterior.
If the back panel is already installed, check whether it fits tightly and if the nails or screws are still secure. This is a simple step that is often overlooked.
SANMAR
12 May 2023 08:59
I understand the feeling when a piece of furniture doesn’t seem as stable as expected. This is especially frustrating with everyday bedside tables. What helped me was not only reinforcing the structural points but also making sure the surface underneath is level and non-slip. Have you tried attaching felt pads or anti-slip pads under the legs?
This also prevents the table from sliding or wobbling with small movements. It might be a helpful additional solution alongside strengthening the joints.
