ᐅ How can I improve the stability of IKEA Metod tall cabinets?
Created on: 30 Nov 2018 20:37
Agathaba
Agathaba
30 Nov 2018 20:37
Hello everyone, I have several IKEA Metod tall cabinets in my kitchen and I am wondering how to most effectively improve the stability of these cabinets.
I feel that the stability of the tall cabinets with multiple compartments is especially weak from the sides when they are slightly loaded or when opening the doors. The standard Metod fittings often seem a bit fragile to me, especially when connecting larger cabinets or assembling them completely by myself.
What additional measures would you recommend to increase the stability and overall sturdiness? For example, certain fasteners, connections between modules, or other tricks?
I would appreciate practical tips that don’t necessarily require major modifications but still provide a noticeable improvement. Perhaps you also have experience handling Metod tall cabinets in a tight kitchen with limited space. Thank you in advance!
gipifa
30 Nov 2018 21:45
Hey Agathaba, great question! I love it when furniture isn’t just set up but actually gets a proper upgrade! 🙂
So, to improve the stability of Metod tall cabinets, I have a few tips that have worked really well for me:
- First of all, always make sure to secure all cabinets to the wall—that’s absolutely essential! IKEA provides suitable brackets, which are invaluable.
- Screw the cabinets together with the appropriate connectors; this greatly reduces wobbling.
- For the tall cabinets, you can also install metal or wooden strips inside to create cross braces.
- Another idea: leveling the base with adjustable feet or small wooden shims—this makes everything truly level.
Agathaba schrieb:
Die Standard-Metod-Befestigung wirkt mir oft etwas fragil
I know that feeling well! That’s why I add extra screws and connectors. It looks really solid and neat when everything is rock-solid! So don’t get discouraged—you can really make a big difference! Good luck, and feel free to share what works for you!
U
usteto
30 Nov 2018 22:05
Agathaba, always make sure to securely attach the cabinets to the wall. Then connect the modules using connector screws. Use leveling feet if necessary to prevent any tilting.
trevor
1 Dec 2018 07:29
Good morning! 😄 It’s great that you’re paying close attention to the stability of the IKEA Metod tall cabinets.
Here’s a simple idea: you can also use decorative moldings to cover the gaps, which simultaneously connect and reinforce the cabinets. It almost makes you feel like a cabinetmaker, and the kitchen looks even more stylish!
Agathaba schrieb:
What additional measures do you recommend to improve the stability and overall sturdiness?
From my experience: the tighter the connection between the cabinets, the less they wobble. And yes, wall mounting is essential—without it, nothing works—that’s the unsung hero of stability! 😉
Hope this helps you as well!
JORDON
2 Dec 2018 18:16
Great topic, especially for tall cabinets like the Metod version with multiple modules that you’re describing!
My tips:
- Always use the supplied metal brackets for wall mounting, as they are essential. Without them, the risk of the cabinets tipping or coming loose is significantly higher.
- If possible, also connect the individual cabinets with screws or angle connectors to make them one unit. This also reduces wobbling when opening the doors.
- Use sturdy leveling feet. Especially on uneven floors, this helps a lot to prevent the cabinets from tipping.
- Sometimes it’s worth adding small wooden or metal cross braces inside at the connection points. They provide additional reinforcement.
trevor schrieb:
The tighter the connection between cabinets, the less everything wiggles.
I fully agree. In the end, stability comes from good wall attachment combined with strong connections between the units. Maybe you’d like to approach it that way?
