I am currently working with my IKEA Platsa furniture and looking for ways to modify it as flexibly as possible. My goal is to quickly and easily reconfigure the modules as needed to create both storage space and perhaps a small workspace at times. I am especially interested in practical tips on how to securely connect the individual components, which combinations work well, and whether there are useful extensions or accessories that can significantly expand the possibilities for modification.
Does anyone have experience with flexibly modifying the Platsa modules without losing stability? I would prefer not to permanently screw anything together, but to keep it flexible. Thanks in advance for your advice!
Bennon schrieb:
My goal is to quickly and easily reconfigure the modules as needed to create both storage space and possibly a small workspace.Hey, great idea! The connectors IKEA provides with Platsa are particularly useful – the so-called connecting fittings. They allow you to attach the individual modules quite quickly and, above all, securely without having to drill. If you want an even more flexible solution, you could experiment with plug connectors or even magnets, which allow for quick assembly and disassembly and hold surprisingly well! 😉
For the workspace: I once combined a module with a cut-down tabletop that you simply place on top of the boxes. The idea was to be able to set it up and rearrange it when I need more space. Pure flexibility!
putan schrieb:
For Platsa, the connecting elements IKEA supplies—the so-called connecting fittings—are especially useful.That’s a good point. To complement the straightforward assembly, I would recommend always attaching the supplied metal connectors at the corners and edges. They not only add stability but also provide a clean appearance. Additionally, thanks to the special screws, the modules can be relatively easily disassembled if changes are needed.
It also often helps to use the back panels—they significantly increase stability and make the cabinet much more robust when modifying or moving it.
Brief and concise: For flexible modifications of the Platsa series, the following approach is recommended:
- Use the original IKEA connecting fittings, which can be applied across different modules.
- Install the back panels even in temporary configurations, as they significantly contribute to stability.
- Add extra metal brackets if heavy loads are planned.
- Consider enhancing modularity by adding caster feet to make the furniture easier to move.
Additionally, I advise not to exceed the maximum load capacity of individual modules to prevent structural deformation. Detailed technical specifications can be found specifically in the IKEA assembly instructions.
praWarre698 Oct 2020 15:16Bennon schrieb:
My goal is to be able to quickly and easily reconfigure the modules as needed, to create both storage space and possibly a small workspace.Hey, that sounds like a great project! If flexibility is key, I’d suggest experimenting with connectors or hook-and-loop fasteners. It adds a bit of a DIY touch, is fun, and keeps things highly adaptable. 😎
Also, you can drill holes in the inner shelves and use adjustable brackets—kind of like a modular system. This works great if you want to vary the height, for example, to accommodate different-sized folders or even use it as a small bar setup.
And: put some casters under the bottom module, so moving it around becomes a breeze.
