Hello everyone, I currently have several Ikea Pax wardrobes in my bedroom and am considering how to expand them as flexibly and modularly as possible. My goal is to easily increase or adjust the existing storage space when needed—without having to dismantle the entire wardrobe each time or require a lot of tools.
I am particularly interested in tips on combining different elements, such as additional interior fittings, extension modules, or clever mounting options that would allow me to integrate new wardrobe doors or add various other configurations as needed.
Has anyone had experience expanding Pax wardrobes in a way that keeps them flexible for future changes, for example, if household needs evolve? Are there any recommended products or tricks to modularly extend the system without compromising stability or appearance? I would appreciate practical advice and your personal experiences!
Hello SEHAIX, regarding your question about the flexible expansion of the Ikea PAX wardrobes, I would like to elaborate a bit, as the system can generally be extended very well in a modular way, but there are some points to consider.
First, I recommend always paying attention to the compatible dimensions when expanding – PAX offers frames in heights of 201 cm (79 inches) or 236 cm (93 inches) and widths of 50, 75, or 100 cm (20, 30, or 40 inches). If you want to combine additional modules, their depths (35 or 58 cm [14 or 23 inches]) must match exactly so that the elements align flush and the doors fit properly. Using different depths unfortunately causes problems.
Second, regarding assembly: For stable connections between multiple PAX wardrobes, special connectors (hidden corner brackets or metal supports) that you can attach behind the frames are suitable. This way, you can connect two or more frames firmly but still allow disassembly later if needed. It’s also important to anchor the wardrobes to the wall, especially for large combinations, to ensure tipping safety.
The interior fittings are also very flexible: Ikea offers various shelves, pull-outs, drawer inserts, and accessories like clothing rods or sliding door systems that you can add or replace at any time. If necessary, individual modules can even be expanded with inserts from third-party suppliers, which sometimes offer more functionality.
Regarding the doors: In addition to the standard doors, you can use hinged or sliding doors to improve handling. If you place several wardrobes side by side, T-solutions or special connecting rails for double doors can be helpful.
One last idea: If you want to experiment with affordable expansions, it often helps to buy individual PAX frames separately and assemble them at home first, so you can later upgrade them according to your needs.
Feel free to briefly describe the exact room you have and which expansions you are planning specifically, then I can address your situation more precisely.
As a supplement: Ikea PAX wardrobes are originally designed for modularity, meaning each extension should fit dimensionally and be compatible with the existing system.
- Consistent frame depth is crucial.
- For connection stability between multiple wardrobes, it is recommended to use the original Ikea joining fittings.
- Shelves, drawers, and clothes rails can be added or rearranged at any time.
- For larger, flexible adjustments, PAX sliding doors are a good option, as they can be positioned more freely than hinged doors.
Avoid combining different depths or incompatible door systems, as this limits functionality and creates a visually inconsistent appearance.
Lorukeo schrieb:
Avoid combining different depths or incompatible door systems, as this limits functionality and can create a visually unbalanced appearance.This is an important detail. Additionally, the fittings and mounting solutions for doors and interior fixtures are not interchangeable between different depths. Improper combinations can also reduce overall stability.
Regarding door systems, it is important to note that sliding doors, due to their specific tracks, do not simply fit on any frame. They are optimized for certain frame heights and widths. Therefore, before expanding, you should know the exact dimensions of the existing cabinet and try to choose extensions with identical specifications.
I also recommend considering the overall height during planning. If your room has an unusual ceiling height, there are riser elements or plinth heights designed modularly, so you won’t encounter issues when expanding.
For these reasons, it is worth planning the extension very carefully and, if possible, working with a tape measure and a sketch before ordering new modules.
Hello SEHAIX,
I would like to structure my response as a small guide that can help you with the flexible extension of your Ikea PAX wardrobes:
1. Planning is key: Start by creating an accurate sketch of your current PAX wardrobes with all measurements.
2. Choose consistent dimensions: Make sure to use frames with the same depth, either 35 cm (14 inches) or 58 cm (23 inches).
3. Use connection elements: Ikea offers special corner connectors or screw profile systems that allow you to securely join wardrobes without dismantling them.
4. Design the interior modularly: Use various shelves, drawers, and baskets to adapt the storage space as needed.
5. Plan the doors: If you want to add extensions with new doors, compare them to your existing door types to ensure compatibility.
6. Don’t forget the base: Use plinths and legs designed specifically for PAX to maintain a seamless look.
Typical mistakes I made myself when extending were:
- Different depths of new modules causing doors not to fit anymore.
- Connections without suitable stability connectors leading to wobbling.
If you like, I can help with detailed planning – just share your measurements and planned extension ideas.
Dilen schrieb:
Feel free to briefly describe the exact room you have and the specific extensions you are planning, so I can address them more precisely.Sure, thanks for the suggestions so far!
My bedroom has a ceiling height of 2.50 m (8.2 feet). The wardrobes currently consist of three PAX units side by side (each 236 cm (7.7 feet) high, 58 cm (23 inches) deep, and 100 cm (39 inches) wide). My main goal is to increase storage space for clothing, but I also want the option to later convert part of it into an open section with shelves or install drawers.
I would prefer to stay flexible with the doors because I might want to leave some sections open later without showing the interior from the outside. That’s why I’m considering an extension that can be easily added to and modified when needed, without having to remove everything.
Do narrower modules (50 cm (20 inches) or 75 cm (30 inches) wide) make sense for extensions, or do they complicate the system? And would you recommend buying new modules or working with the existing ones and only adjusting the interior?
