ᐅ How can I adapt Ikea Besta furniture flexibly to changing room layouts?
Created on: 15 Apr 2024 08:37
Isarka
I am facing the challenge that my living situation will change significantly within the next year — new room layouts are planned, with shifted door openings and different usage scenarios. I own several IKEA Besta units, which I actually appreciate a lot, as they are solid and versatile.
My question to the community: How can I adapt my existing Besta furniture as flexibly as possible so that it can still be used effectively with new floor plans? Specifically, I am interested in practical tips or ideas for modifications to adjust the modules through rebuilding, additions, or repositioning to accommodate changed room sizes, shapes, or wall openings. Are there any tricks for combining the basic elements that provide long-term flexibility?
Perhaps someone also knows interesting modifications such as resizing, rehanging fronts, or changing the compartment layouts?
Looking forward to your suggestions, thanks in advance!
tra_nina
17 Apr 2024 12:21
I would like to add that when modifying the Besta systems, the hardware system also plays an important role.
- The standard fasteners are designed for certain loads, but if you often rearrange modules, you should have suitable screws and connectors from IKEA or equivalent sources ready.
- For additional stability, especially with room dividers, metal brackets can be helpful.
- In addition, IKEA uses standardized dimensions, which allows you to incorporate additions from other furniture series or custom-made elements, as long as they are compatible.
- Finally, I recommend paying close attention to high-quality hinges and guide rails for moving parts, since frequent rearranging can affect stability.
Without considering these points, your furniture may wear out faster or become less flexible.
KNUTGI
18 Apr 2024 09:04
vin_leo schrieb:
Flexibility comes from modularity – just try it out and renovate step by step. 🍀
I completely agree! Last year, after moving, I completely reassembled my Besta unit – some modules are shorter, others taller, and thanks to adjustable shelves, I can rearrange things anytime.
One more tip I can recommend: use casters on individual modules if you want to move them. This way, you get the perfect balance between stability and mobility – and no fear of new space layouts!
Besta really is a true chameleon, as vin_leo says.
