Hello everyone, I am planning to get an Ikea Platsa system and want to equip it with LED lighting to enhance the look and also improve the interior illumination. I am now facing the challenge of deciding which type of LEDs are most suitable, how to best set up the power supply, and how to install everything so that it remains neat and as invisible as possible. Does anyone have experience with which LED strips or lights work well, how to manage the wiring effectively, and whether there are specific mounting options that fit directly on or inside the Platsa unit? I would appreciate tips on planning, selecting components, and advice on common pitfalls or frequent mistakes.
Hello Lirole,
your idea to illuminate the Ikea Platsa with LEDs can be realized quite easily in a few steps. Here is a brief guide on how to proceed:
- LED selection: Flexible 12V LED strips, preferably dimmable, are recommended. This simplifies installation and is safer than a direct 230V (120V) connection.
- Power supply: Use a 12V power adapter with sufficient output, usually 24W or 36W is enough for standard cabinet lighting.
- Installation: The Platsa modules usually have enough space on the sides to stick the LED strips inside. Make sure the surface is clean and free of residue before applying the strips.
- Cable management: Route the cables so they remain hidden behind the module parts. Cable ties or specialized clips help keep everything secure.
- Switch/light control: If you want dimming, a compatible LED dimmer is recommended. Alternatively, you can install smart LED strips with remote control.
Common mistakes:
- Attaching LEDs directly to uneven surfaces, which can reduce adhesion.
- Using a power supply that is too weak, causing flickering or unstable lighting.
- Measuring cables too short; it is better to leave some spare length.
If you need more details, just ask!
Common mistakes:
LOJOPAR schrieb:
The Platsa modules usually have enough space on the sides to attach LED strips inside.That’s a good tip and it’s definitely accurate. It’s also important that the LED strips have an appropriate IP rating if you’re planning to use the cabinets in slightly damp rooms, for example.
Additionally, pay attention to the color temperature of the LEDs – warm white (around 2700K to 3000K) creates a cozy atmosphere, neutral white (3500K to 4000K) is more neutral and clear, while cool white (over 5000K) can sometimes feel harsh in living spaces.
If you want to illuminate not just the cabinet frames but also the interior, there are small spot LEDs or light bars designed specifically for that purpose. These can often be mounted using small magnets or adhesive.
Another thought: if you expand the system, it’s advisable to use a central wired power supply with splitters to reduce trip hazards from cables.
Good luck with your project!
gregto schrieb:
Another thought: If you plan to expand the system, a central wired power supply with splitters is recommended to reduce trip hazards related to the power supply.To elaborate further: Especially with Ikea Platsa, which is modular, you should plan the power supply carefully. Keep in mind:
- Which lengths and modules will be illuminated? The longer the strips, the higher the current and possibly the cross-section of the supply cables must be. Otherwise, voltage drop can cause uneven lighting.
- Route the cables from the start in a way that allows flexible expansion. I recommend using small multi-port splitters, preferably with screw terminals for secure connections.
- Secure the cables with clips along the inner sides of the Platsa modules. This prevents loose cables that could get caught in drawers or when opening them.
- Watch out for heat buildup: LED strips can warm up over time, so it is sensible to mount them on metal profiles or aluminum channels – this protects and prolongs their lifespan.
- For control: If you want to use an Arduino, HomeKit, or similar, it’s worth investing in WS2812B LED strips (addressable LEDs). However, the functionality will be more complex.
Do you already have an idea of how extensive the lighting should be? The more precise, the better the planning can be.
