ᐅ How can I equip Ikea Metod kitchen cabinets with soft-close doors and drawers?
Created on: 5 Nov 2017 10:07
jaColette
jaColette
5 Nov 2017 10:07
I am currently planning the custom features for my new IKEA Metod kitchen and have an important question: How can I equip the Metod kitchen cabinets, especially the doors and drawers, with soft-close mechanisms? My goal is to enhance comfort by ensuring all doors and drawers close gently and quietly.
I am particularly interested in the following points:
- Which soft-close options or fittings are compatible with IKEA Metod fronts?
- Are there any special installation tips or common mistakes to avoid when retrofitting?
- Is it possible to modify cabinets that are already fully assembled, or is it better to install soft-close mechanisms during the initial assembly?
I would appreciate detailed and practical advice, preferably based on firsthand experience. Thank you in advance!
Lidan56
5 Nov 2017 11:16
The simplest option is to use Ikea's own soft-close fittings, designed specifically for Metod doors and drawers.
Installation is straightforward, and your Metod furniture is prepared for this upgrade. Just remove the old hinges or drawer slides and install the soft-close versions.
If you want to use other brands, be sure to check the measurements carefully, otherwise they might not fit.
kulau
6 Nov 2017 08:43
Hello jaColette,
you have asked a very important and somewhat complex question. Retrofitting soft-close on Ikea Metod furniture requires detailed knowledge – here is a comprehensive overview:
- By default, Ikea offers the Metod series with pre-installed hinges; some of these already include soft-close.
- For doors without soft-close, you can retrofit original Ikea dampers; these are well matched to the Metod fronts. The damper is either clipped or screwed onto the hinge, depending on the model.
- For drawers, you should pay attention to the appropriate slide system with integrated soft-close function. Metod drawer slides are available both with and without damping as standard. Retrofitting is possible, but the dimensions must be considered to ensure smooth operation.
Tips for installation:
- Doors can usually be retrofitted after the cabinets are assembled, but you need to work very precisely to avoid misalignment.
- For drawers, it is better to replace the slides, which usually requires removing the entire drawer.
- Always check compatibility, as the soft-close mechanisms have been modified several times since the Metod series was introduced.
Do you already have a kitchen with specific models? That might simplify the selection. If you like, I can also provide typical installation steps as well as important tool and material recommendations.
klo40
7 Nov 2017 19:21
Hello jaColette,
I would like to organize my response so you can follow clear instructions:
1. Equipping Doors with Soft-Close:
- Check whether your current Metod doors have cup hinges and if these are compatible with soft-close dampers.
- If not present, you can purchase Ikea soft-close dampers separately, for example, the "METOD stopper and damper" model.
- For installation: Simply clip the damper into the designated area on the cup hinge. Note that for older models, small pilot holes may sometimes be necessary.
2. Soft-Close for Drawers:
- Metod drawers often come with BLUMOTION or similar soft-close systems already installed.
- If you have drawers without damping, you can replace the entire set of drawer slides with soft-close slides. This is especially recommended for the larger drawers.
3. Mistakes to Avoid:
- Buying incompatible dampers that do not exactly fit the Metod series.
- Using doors or drawers without properly adjusting the dampers, as this can cause faster wear.
- After installation, it is important to adjust the doors and drawer alignments to ensure the soft-close function works well.
Summary:
- Ikea offers its own soft-close components that are easy to install.
- Retrofits are possible but vary in complexity depending on the model.
For installation, work at a well-lit workspace with appropriate screwdrivers. Sometimes a small hammer or a plastic wedge can be helpful to position the dampers correctly.
I can also provide a rough step-by-step guide if you like.
