ᐅ How can I equip Ikea BESTA units with glass or acrylic fronts?
Created on: 5 Oct 2024 18:24
Dresdensi
Dresdensi
5 Oct 2024 18:24
Hello everyone, I am currently planning to upgrade my IKEA Besta sideboard with high-quality glass or acrylic fronts and am looking for practical solutions. Specifically, I am interested in how to replace the original fronts with glass or acrylic panels without compromising stability or functionality, such as hinges and handles. Are there proven methods for mounting or fastening that allow you to either reuse or repurpose the existing fittings? Also, regarding cutting to size—are there special measurements to consider, and are certain types of glass or acrylic better suited in terms of weight and break resistance? Additionally, do you have any tips for surface treatment if adhesives or seals are used? Thanks in advance for your input!
DUVIN
5 Oct 2024 19:02
For glass fronts, it’s best to use thin toughened glass, which is durable and relatively lightweight. Acrylic is lighter and less prone to breaking, and easier to work with. Mounting: it’s best to get aluminum profiles or clips to hold the glass. The original hinges usually continue to work, but the fronts must be cut to exact measurements. Make sure to measure dimensions precisely, otherwise it won’t fit properly.
tra_nina
6 Oct 2024 08:43
As an addition: When converting the IKEA BESTA with glass or acrylic fronts, it is important to securely fasten the front panels. Since the original wooden or MDF fronts usually rest on frames or the back panel, profiles made of aluminum or plastic are recommended as spacers and fastening elements. For glass, safety glass (tempered glass) should always be used, as it breaks into small, harmless pieces. Acrylic, on the other hand, is lighter and especially suitable for DIY cutting but is more prone to scratches. It is also advisable to finish the edges professionally (e.g., polishing) to prevent cracks and scratches. Adhesives should be solvent-free and specifically suitable for glass or plastic, ideally silicone-based, as they remain flexible and do not create stresses in the material. Important dimensions include the cutouts for hinges and handles, which often need to be adjusted. It is definitely worthwhile to order high-quality cuts to ensure perfect fit.
likuken
7 Oct 2024 12:11
DUVIN schrieb:
Fastening: It’s best to buy aluminum profiles or clips that hold the glass.
It’s interesting that aluminum profiles are often immediately recommended as the solution. In my experience, this is often overrated—not everyone wants their sideboard to look like an industrial product. A smooth, neatly applied silicone adhesive is often sufficient for acrylic, providing an elegant and slim appearance. Of course, the original hinges are a challenge, but they can be adapted with thin spacers or even replaced to make the whole setup more customized and flexible.
tra_nina schrieb:
Acrylic, on the other hand, is lighter and particularly suitable for DIY cutting, but it is more prone to scratching.
Regarding scratches: acrylic surfaces can also be restored with special polishes to remove minor damage. Glass is more expensive but usually less vulnerable in everyday use. Nevertheless, with careful handling, acrylic can easily keep up and has the advantage that you can achieve any color or level of transparency. I think it’s worth considering options beyond the classic standard solution of aluminum profiles.
