Hello everyone, I am planning to move soon and intend to take my Ikea Platsa furniture with me. Since PLATSA units are modular and can become quite bulky depending on the configuration, I would like to know: What is the best way to transport Ikea PLATSA easily? I am mainly looking for tips on how to best disassemble, pack, and secure the furniture parts to ensure they arrive undamaged and efficiently. Are there proven methods or special accessories that can make the transport as simple as possible? Additionally, I would like to know if parts like the back panels or hinges can be prepared in a particular way to avoid damage. I look forward to your detailed experiences and advice!
Hello Lauhau,
First of all, an important note: Disassembling Ikea PLATSA is generally quite straightforward, but depending on how your modules are assembled, some precautions can significantly ease the transport.
I recommend the following procedure, which has proven effective in my experience:
- Phase 1: Disassembly
- Start by removing all shelves and drawers to significantly reduce the weight.
- The back panels are usually fixed only with nails; you should carefully remove them using a putty knife or a thin prying tool, as they tend to break easily.
- Store screws and fittings individually in small bags and label them with the corresponding module.
- Phase 2: Packaging
- Use sturdy moving boxes or bubble wrap to protect the disassembled parts from scratches.
- Pay special attention to protecting hinges and edges, as they can be damaged by impacts.
- For longer transports, it is advisable to wrap wooden parts in blankets and secure them with straps.
- Phase 3: Transport
- Place heavy parts (e.g., side panels) at the bottom to prevent them from being crushed.
- Use hand trucks or dollies to move the modules more easily from one place to another.
One important tip: If you can store the frames intact after disassembly, it will greatly facilitate reassembly later. Also, label the individual parts either with tags or photos.
I would be interested to know how many modules you plan to transport and whether you have a van available or if transportation will be done in a private car – this significantly affects the approach.
Hello Lauhau,
I’d like to add some basic tips about transporting Ikea PLATSA, especially if you’re not used to disassembling furniture regularly.
- The PLATSA components are modular and often made of particleboard, which is sensitive to moisture and impacts. Make sure to protect the surfaces and edges well.
- For packing, special stretch wrap, which you can get at most hardware stores, works well. It not only prevents scratches but also keeps all parts securely together.
- If you empty and store the drawers separately, you should also put them in protective covers to avoid damaging the runners.
As a general rule for transport-ready disassembly: the bare individual parts carry a lower risk of damage during transport. Sometimes it’s advisable to fully dismantle the PLATSA and secure the parts individually. Be sure to label the screw packs – this saves a lot of time searching later on.
If you need help carrying the items, I also recommend moving blankets – they are soft, large, and usually inexpensive. By the way, if you’re using a specific vehicle type for transport, feel free to mention it here so we can provide more tailored advice.
Palenar schrieb:
If you can store the frames intact after disassembly, it makes the later reassembly much easier.This is a point I’m somewhat skeptical about, at least from my perspective: While disassembling into individual parts does reduce volume for "easier transport," it also increases the effort needed for loading. Even the frames alone can still be bulky. So, of course, it depends on the type of transport vehicle used.
TRADI schrieb:
The more stripped down the individual parts are, the lower the risk of transport damage.I only partially agree with that. Of course, fewer assembled units are easier to stack, but not always more stable. Sometimes the structure itself protects the interior better than completely dismantled boards that then lie loose in boxes and may collide with each other.
In my opinion, a middle ground is often best: break down large modules enough to be transportable but still as stable as possible. You should definitely remove the back panels because they are fragile, but for example, drawer units can sometimes stay partially assembled if well padded.
Finally, my questions for Lauhau:
- How long are your travel distances?
- What transport options do you have (car, van, moving company)?
- How much experience do you have with furniture assembly and moving in general?
With this background, much more targeted advice can be given, since "easy transport" is often too general without context.
