ᐅ How can I easily relocate IKEA PLATSA furniture during renovations?
Created on: 21 Oct 2023 18:23
philippdoP
philippdo21 Oct 2023 18:23Hello everyone,
I am currently facing the challenge of moving or disassembling some IKEA Platsa furniture during our upcoming renovation, and then reassembling it later without issues. Since the PLATSA series is modular and often custom-designed, I’m wondering how others handle situations where walls are being painted or floors replaced and the furniture needs to be temporarily removed.
Specifically, I’m interested in the best steps to avoid damage to the furniture, how to dismantle the individual components in a way that makes transport easy, and whether there are tips for organizing the disassembly systematically to save time during reassembly. Perhaps you also have tricks for protecting or keeping track of fittings and hinges so nothing gets lost.
I’m looking forward to your practical experiences or recommendations for tools or aids that might simplify the process.
Thanks in advance!
Thanks in advance!
Hello philippdo,
I completely understand how annoying it is to have to disassemble furniture during a renovation – especially with PLATSA, as there are so many things to consider.
I noticed in a similar renovation that it’s really helpful to keep all screws in labeled plastic bags. This makes it much easier to stay organized later on.
Also, I definitely recommend having the instructions handy or taking photos before you start. When disassembling, it helps to work systematically – so don’t just start anywhere, but for example, remove covers first, then pull out drawers, and finally detach the side panels. The back panels are often delicate, so I had to be careful not to tear anything.
It’s also perfectly okay to take a short break and not work under time pressure, as rushing usually just makes the process frustrating. I hope this helps you a bit!
philippdo schrieb:
how best to take apart the individual components so they can be transported without much effort
The process of relocating IKEA PLATSA furniture during renovations can be significantly simplified with a structured approach.
- Store screws and fittings in small, labeled containers to prevent loss.
- Before disassembly, it is advisable to take detailed photos of all connections and the interior structure—preferably from multiple angles.
- A cordless drill with adjustable torque is recommended for removing parts to minimize damage to the connectors.
- The individual components should be laid flat, well padded, and stacked or packed in the order of disassembly whenever possible.
- With PLATSA, it is important to handle the back panel carefully, as it serves only for stabilization and is easily damaged.
Maintaining the assembly sequence will make reassembly much easier. Additionally, it is helpful to have the product specification sheet and assembly instructions close at hand. For larger elements, planning for a second person to assist can also simplify handling.
This approach minimizes the risk of damage and avoids unnecessary loss of time.
philippdo schrieb:
Are there any tips on how to organize the dismantling process systematically to save time during reassembly?First, remove drawers and fronts, then the side panels. Keep screws sorted and labeled, and remove the back panel last.
philippdo schrieb:
Any tricks to protect or secure fittings or hinges?The best way is to put them in freezer bags and attach them to the respective furniture parts.
This will save you a lot of time later.
