ᐅ How can I dispose of IKEA Brimnes furniture in an environmentally responsible way?
Created on: 20 Dec 2016 08:43
Suli4
I am currently facing the problem of how to dispose of my IKEA Brimnes furniture as sustainably as possible. Since it is made from different materials—mainly particleboard with laminates, plastic parts, and metal fittings—I don’t want to just put everything out with bulky waste. Are there any proven strategies for preparing or separating the furniture to make disposal more environmentally friendly? I am thinking of recycling centers, waste collection points, or maybe even upcycling options. What methods do you know that are ecologically sensible and, ideally, easy to carry out? Thanks for your tips!
PRA64 schrieb:
If possible, resell or give away individual partsThis is an important point. However, I wonder how realistic it is: IKEA furniture is relatively easy to replace, and Brimnes has a wide customer base. Apart from well-known platforms, are there alternative ways to find a suitable recipient for damaged or incomplete parts?
janeo schrieb:
I wonder how realistic that is: IKEA furniture is relatively easy to replace, and Brimnes has a broad customer base.That’s a valid point. In my specific case, however, the drawers and side panels are still in good condition. I was considering offering them through neighborhood groups or for upcycling projects. For damaged parts, I am also skeptical since the demand is probably low. The main goal is to avoid waste rather than simply disposing of them as garbage.
I can add that proper dismantling is crucial to correctly separate the materials. A common issue with Brimnes furniture is that paper or foil coatings contaminate the particleboard, which means it cannot be classified as pure wood. At the recycling center, this is usually categorized as mixed metal or bulky waste, which lowers the recycling rate.
My advice:
- Separate screws and metal parts by module
- Remove any remaining foil with a scraper before disposal
- Break down particleboard into as large and clean pieces as possible
This way, you at least improve the chances for material recycling.
My advice:
LuMarcel43 schrieb:
Does anyone have experience with how this is handled in different regions?From my experience, uncoated wood chipboards are widely accepted at recycling centers in Germany, as long as the waste is not contaminated with large amounts of plastic or foil. In some federal states, there are stricter regulations that only accept coated old wood as residual waste.
Therefore, it is important to check locally when in doubt to avoid disposing of the material through the wrong waste stream. This also applies to plastic components, which are not always allowed at recycling centers.
For the sustainable disposal of Brimnes furniture, I usually use the recycling center. There, I take the furniture apart, sort the wood, metal, and plastic, and hand them in accordingly. If the furniture is still in good condition, I give it away or offer it on online platforms.
