ᐅ How can I disassemble Malm furniture without causing any damage?
Created on: 4 Dec 2023 07:43
meodan70
Hello everyone, I would like to know the best way to disassemble Malm furniture from IKEA without damaging the material or surface. I’m especially interested in which tools are most suitable, how to methodically approach the screws or connections, and if there are any common pitfalls to avoid. I plan to take apart a bed and possibly some dressers to make them easier to transport for a move. I would be very grateful for tips, step-by-step instructions, or tricks.
ju_ren
5 Dec 2023 06:52
Don't forget: Always completely remove screws and keep them in a safe place. Malm does not use nails, so you won't damage the wood when taking it apart.
lubla
5 Dec 2023 07:32
If you don’t have the original tools, get hex keys in the correct sizes. Properly fitting tools reduce the risk of stripping screws.
Jukin
5 Dec 2023 08:15
ju_ren schrieb:
Don’t forget: Always completely remove screws and put them in a safe place.
Exactly. That’s the only way to ensure nothing is missing when reassembling later and to avoid damage from partially loosened connections.
lubla schrieb:
If you don’t have the original tools, get Allen keys (hex keys) in the right sizes.
This is especially important because IKEA often uses metric sizes, which may not be compatible with US tools.
Also, if you take the bed apart, you can try lightly treating the metal fittings with olive oil when removing them if the screws feel too tight — but only sparingly, to avoid staining the surfaces.
U
usbla
5 Dec 2023 09:41
Regarding surface protection: At Malm, the fronts and side panels are often laminated with a foil. The risk is that if they are released too quickly or forced at an angle, the foil can tear.
Therefore, I recommend using sturdy but wide wooden wedges between components instead of metal levers. This protects the edges from damage and allows for controlled separation of the joints.
sanjon
6 Dec 2023 11:29
Summary: Use the right tools, unscrew screws straight, secure small parts, place protection underneath, and be patient. This ensures everything goes smoothly.
