ᐅ How can I make disassembling and reassembling an Ikea HEMNES easier?
Created on: 23 Nov 2018 08:37
Julianok46
Julianok46
23 Nov 2018 08:37
Hello everyone, I’m looking for effective methods to make disassembling and reassembling the Ikea Hemnes wardrobe easier. I’ve noticed the process is quite cumbersome, especially when you need to move it multiple times, such as during a relocation or room renovation. Are there specific techniques or tools that have helped you with taking it apart or putting it back together later? I would especially appreciate tips on how to handle the screws and supplied connectors without damaging or losing them. Ideas on how to keep track of the many individual parts would also be very helpful. Thanks in advance for your suggestions!
jokau
23 Nov 2018 09:12
To disassemble the cabinet, start by taking it apart from the inside out. You should remove screws with a magnetic screwdriver to avoid losing them. It is best to collect individual parts in labeled boxes.
meoka
24 Nov 2018 13:05
[@Julianok46, post: c1z7p0, member:XXX]
Hello everyone, I’m looking for effective methods to more easily disassemble and reassemble the Ikea HEMNES wardrobe.
A good approach is to take detailed photos of each assembly step before taking it apart. This way, you have a visual reference when putting it back together. I also recommend:
- Use small zip-lock bags or containers labeled with the respective assembly instructions or parts to systematically store screws and fasteners.
- Use a cordless drill with a torque setting to avoid over-tightening or damaging the screws.
- Carefully remove the back panel, as it provides stabilizing support. Try to remove it last.
Common mistakes:
- Fully unscrewing all screws at once, causing the parts to fall apart uncontrollably.
- Mixing up different types of screws.
I hope these tips help you.
@jokau
I agree, the labeled containers are worth their weight in gold.
U
usbla
25 Nov 2018 21:44
meoka schrieb:
- Carefully remove the back panel, as it serves as the stabilizing structure. Remove it preferably last.
This is an important tip. Additionally, it is recommended to:
- First install the back panel during assembly to ensure stability.
- Use a screwdriver with a good grip or a cordless drill with torque control to avoid damaging the wooden parts.
- Keep track from the start of which screws belong to which part, preferably in a notebook or digitally.
The advice to store screws in small, labeled containers also significantly reduces the risk of loss and increases efficiency during reassembly.
Leonardteo
27 Nov 2018 11:11
Julianok46 schrieb:
Are there specific techniques or tools that make disassembling or later reassembling easier for you?
From my experience, it helps to immediately place all screws and connectors into separate, organized containers during disassembly and to mark the panels in case the instructions are no longer available. A good cordless drill with adjustable torque is also recommended to avoid splitting components or damaging screws during assembly.
Additionally, when taking things apart, avoid using force. Instead, systematically remove all screws and dowels step by step before separating the parts. It’s best to work from an ergonomic position to prevent applying pressure in awkward spots.
