ᐅ How can I design living room wall units using IKEA PLATSA?
Created on: 8 Oct 2023 19:23
bole2
bole2
8 Oct 2023 19:23
Hello everyone, I’m currently planning to design a wall unit using IKEA Platsa and want to connect the individual modules as flexibly and aesthetically pleasing as possible. I’m interested in design options, such as which combinations of cabinets, open compartments, and doors work best, as well as tips for color and material choices in the context of modern living rooms. Additionally, it would be great if someone could share their experience regarding wall mounting or practical extension options like integrated lighting. How can Platsa be best used to create a functional yet visually attractive wall unit? Looking forward to your ideas and suggestions!
geralu
8 Oct 2023 19:38
I recommend starting with a base of large cabinet units to create storage space. Then you can alternate open shelves and doors to add variety and a sense of openness. Securing the units to the wall is important, so be sure to use the supplied wall brackets. Many people choose white or light colors, as these appear timeless and modern.
Nabla64
9 Oct 2023 08:11
Hello bole2,
For designing your PLATSA wall unit, I recommend the following approach:
- Planning: Measure the room precisely and consider how much storage space you need and which items you want to store.
- Combinations: A mix of closed cabinets for storage, open shelves for decoration, and possibly drawers for small items offers a good balance.
- Color selection: Light colors like white, light gray, or wood finishes suit modern interiors well, but darker doors as accents are also possible.
- Mounting: Be sure to use the supplied wall brackets and attach them to a solid wall, preferably masonry or load-bearing walls.
- Extensions: For lighting, LED strips behind open shelves are ideal and relatively easy to install yourself.
Avoid mixing too many different modules randomly, as this can look chaotic. A clear, linear design greatly improves the visual appeal.
If you like, I can also create an example for a specific configuration.
Wesley
9 Oct 2023 13:27
Nabla64 schrieb:
LED strips behind open shelves are ideal for lighting, and you can install them yourself quite easily.
Absolutely! It really makes the wall unit a real eye-catcher, especially in the evening. 🎉 I used warm white LEDs myself – they create a really cozy atmosphere! And honestly, with PLATSA you have a sort of modular advantage, which actually makes designing fun. Just go for it and give it a try!
sifope
10 Oct 2023 07:54
I see this a bit more nuanced. The standard wall fasteners from IKEA are acceptable, but they aren’t suitable for all wall types. It’s best to carefully check the wall condition before installation or, if necessary, get professional assistance. Otherwise, the weight of the modules could pose a safety risk.
Regarding design: I wonder if it’s really worth mixing different colors, as this can quickly look busy. A more uniform color choice is usually clearer, but it limits design flexibility.
What are your experiences with mixed colors and fastenings – is the visual appeal sometimes more of a driving factor than actual practicality?
GiRoyce
10 Oct 2023 11:18
sifope schrieb:
The standard wall fasteners from IKEA are okay, but they are not suitable for all wall types.
I agree! Especially with drywall, it’s important to use special anchors and definitely observe the load limits.
Regarding color design: If you’re unsure, it’s a good idea to start with a base color and then add accents with accessories or individual doors. This can lighten up the overall look without making it seem cluttered.
About the modules: I’ve had very good experiences with the PLATSA vertical connectors to securely join multiple modules. Also, the flexibility is a big advantage if your living situation changes.
