I am currently planning to install IKEA Metod countertops in my kitchen and am facing the challenge of cutting and fitting them precisely. My question is: which tools and techniques are recommended to cut the countertops accurately without causing significant chipping or rough edges? Additionally, I am interested in the best methods for installing the countertops, especially where they meet each other or rest against walls. Are there specific tips for gluing, screwing, or sealing? I have read that IKEA offers special connectors for this purpose, but how exactly do you work with them? I would appreciate practical and as detailed advice as possible to avoid costly mistakes. Thanks in advance!
Genuan schrieb:
One tip: Before the final cut, create a cardboard template to test the measurements and angles.That is very sensible! It’s best to fit it directly on the wall and make several test cuts before cutting the actual panel.
Also recommended: Lightly sand the cut edge of the countertop before installation. This makes bonding easier and helps prevent chipping on the edges.
So, if anyone is still working on this: use enough screws for the connectors, yes, but don’t overdo it – the board should still be able to "breathe" a little. And don’t forget to treat the visible edges after installation with special countertop edge paint or oil; it helps protect against wear and simply looks good!
Thanks to everyone for the helpful tips, especially the advice on cutting from below and the idea of using a cardboard template. I will get a guide rail and make the template tomorrow.
The assembly process with the connecting fittings is much clearer to me now.
I will get back to you if any questions come up during the build. It’s great to see such helpful support here!
