ᐅ How can I customize the color of Ikea PLATSA furniture?
Created on: 25 Aug 2024 19:07
Manfo
Hello everyone, I am considering how to customize the color of my Ikea Platsa furniture since the standard colors just don’t suit my living room. Specifically, I am looking for ways to change the surfaces without compromising the stability or appearance of the furniture. Has anyone had experience with painting, applying adhesive covers, or even changing the fronts? I am especially interested in which materials or paint types are suitable to achieve a nice and durable result. Maybe also some tips on surface preparation and the best working methods? Thanks in advance!
juMira46
27 Aug 2024 09:15
Oh, I love this topic! ? I covered my shelving unit at home with colored vinyl film – it’s pretty easy and instantly changes the look. The key is to make sure the edges are clean and to firmly press the film down to avoid air bubbles. And a little tip: if you really want color, try using Sharpies for small accents! ?
Manfo
27 Aug 2024 11:39
Nabla64 schrieb:
A common mistake is skipping the primer, which causes the paint to peel off quickly.
Thanks for the tip; that sounds very plausible and explains my previous failure. What about stability when covering or painting fronts, for example with foil? Are there limitations on how much moisture or stress these surfaces can withstand? Also, I would like to know if hinges and fittings must be removed before painting.
nubar
27 Aug 2024 13:27
Manfo schrieb:
What about stability when I cover fronts with foil or paint them? Are there any limitations regarding how much moisture or stress these surfaces can handle?
Good question. Painting with suitable coatings does not affect stability; in fact, it usually offers better protection against moisture and scratches. Foils are generally less durable against mechanical stress and moisture at the edges. It is important that the foil is applied cleanly, as moisture trapped underneath can cause damage.
Manfo schrieb:
Should hinges and fittings definitely be removed before painting?
It is advisable to remove them. This prevents uneven paint edges and allows you to clean and, if necessary, lubricate the parts. Additionally, it helps avoid damage to the fittings.
BARSAN
28 Aug 2024 07:51
When painting the fronts, you should definitely remove the hinges. The paint will adhere better, and you will avoid issues during assembly. For veneers, ensure a clean surface; I recommend using special furniture veneers rather than simple stickers. They last significantly longer.
