I am planning to customize the color of my Billy bookshelf doors, so I don’t want to stick with the standard colors but instead create a unique look. My specific question is: which materials, techniques, and preparations do you recommend if I want to paint or change the color of the BILLY doors without damaging the surface or losing their functionality?
Are there any special paints or primers that have proven effective? Also, is there anything I should particularly keep in mind regarding the door installation or the modification process? I have already done some online research, but practical tips from the community are always more helpful. Thanks in advance for your support!
Davidleo schrieb:
It’s really fun to creatively customize your own piece of furnitureI can confirm that! But at first, I was also unsure whether the paint would last or if the doors might get damaged. For anyone feeling hesitant: with the right preparation and a bit of patience, it really works, and it feels great to create something of your own.
Don’t be discouraged by early mistakes. 🙂
In summary, I would recommend the following: The best approach is to thoroughly clean the doors to remove any grease and dust layers before painting, then carefully sand them (using 240 grit or finer). After that, apply a primer suitable for plastics, which significantly improves adhesion.
For the paint, acrylic paint or a 2K (two-component) paint can be used if you have the necessary equipment. Sanding between coats (starting with 400 grit sandpaper or finer) ensures a smooth finish. Finally, seal with a clear coat to provide durable protection for everyday use.
This method complies with furniture industry standards and has been tested on melamine-coated surfaces like those found on BILLY.
