Hello everyone, I am planning to customize my IKEA Brimnes furniture to better suit my needs and give it a more personalized look. Specifically, I am interested in the possibilities to visually enhance or functionally expand the modular pieces—such as installing lighting, adding extra storage solutions, or making surface modifications like painting, applying vinyl wraps, or fitting new handles.
Additionally, I would like to know how stable the furniture remains after these kinds of modifications and what craftsmanship details need special attention to avoid compromising the material integrity. Perhaps some of you have experience with creative modifications that go beyond the usual changes?
I look forward to detailed tips, recommendations on tools and materials, as well as advice on durability and safety when customizing. Thanks in advance!
I can confirm the advice regarding caution with drilling and the surface.
If you want to paint, proper sanding and the use of suitable primer are essential. For films or laminates, make sure to use high-quality products specifically recommended for furniture.
Installing interior lighting is also relatively simple. You only need a suitable transformer and LED strips, which often come with plug connectors. You should consider cable management to ensure everything looks neat and is not obstructed or damaged later.
If you like, I can also give you tips on how to achieve elegant and safe cable routing.
For expansion: If you want to modify the Brimnes furniture functionally, carefully consider how to optimize storage space. Storage boxes or custom inserts made from plywood can be precisely cut and attached to the furniture.
For sturdy modifications, it is best to use the original wood connectors (cam locks) whenever possible and add additional reinforcements only as a supplement.
Here is a tip for installing handles: If the existing hole spacing does not fit the new handles, use wood filler to close the old holes and drill the new ones carefully. Use screws of sufficient length and, if necessary, washers to ensure a secure hold.
For the aspect of durability in renovations, I also recommend carefully checking mechanical stresses.
Especially when installing lighting, it is important to ensure secure fastenings – adhesive tapes are convenient but can lose effectiveness due to moisture or temperature changes. Screwing into solid surfaces or combining screws with mounting adhesive provides a more durable solution.
Regarding coatings, the usability of the furniture is only affected if the primer and paint are suitable. A multi-layer structure offers better protection against scratches and wear.
LEVI41 schrieb:
When installing lighting, it is especially important to use secure fixingsI completely agree. Additionally, I would like to point out that safety must also be considered when wiring: cables should, where possible, be routed inside cable conduits or behind furniture to prevent damage.
LUSAR schrieb:
If the existing drill spacing does not match new handles, use wood filler to close old holesThat’s a valuable tip that is often overlooked. A smooth finish really makes a difference visually—don’t forget to sand well after filling.
Finally, patience during remodeling is important; it’s better to take small steps rather than changing everything at once and later regretting it.
