Hello everyone, I am planning to customize my IKEA Brimnes furniture to better suit my needs and give it a more personalized look. Specifically, I am interested in the possibilities to visually enhance or functionally expand the modular pieces—such as installing lighting, adding extra storage solutions, or making surface modifications like painting, applying vinyl wraps, or fitting new handles.
Additionally, I would like to know how stable the furniture remains after these kinds of modifications and what craftsmanship details need special attention to avoid compromising the material integrity. Perhaps some of you have experience with creative modifications that go beyond the usual changes?
I look forward to detailed tips, recommendations on tools and materials, as well as advice on durability and safety when customizing. Thanks in advance!
Hello Ixnachen, your project sounds really exciting and is a great way to personalize furniture pieces. Basically, there are quite a few things you can do with Brimnes furniture:
- Lighting can be easily implemented with LED strips, which can be placed inside cabinets or shelves – soldering or sticking them with double-sided tape is usually sufficient, but make sure to have a reliable power supply and accessible wiring.
- Surface: Painting and applying adhesive film are common methods. For painting, I recommend a fine primer designed for wood, since Brimnes is usually made of particleboard with a melamine coating. Applying self-adhesive furniture film is easier and reversible. It is important to clean the surface thoroughly beforehand.
- Changing handles can significantly alter the character; IKEA offers alternatives, or you can find rustic or modern handles at hardware stores.
- Stability: Modifications requiring holes or cutouts can reduce load-bearing capacity. Use drilling sparingly and avoid larger recesses, especially on load-bearing parts.
Your consideration regarding durability is very important. I recommend always testing first in inconspicuous areas and, if necessary, using reinforcement brackets or additional screws. Feel free to ask if you have any questions!
Wow, Ixnachen, that sounds like a fantastic project! I just upgraded my Brimnes wardrobe with RGB LED strips – it really adds a great atmosphere to the room! 🙂
- Pro tip: Besides LED strips, you can also use small battery-powered lights if you don’t have an outlet nearby.
- When painting, definitely choose matte or satin finish; it looks much more elegant than high gloss!
- And replacing handles is super easy—I got some with a vintage look, and it completely changes the vibe!
Keep us updated, I’m really curious to see how it turns out once you’re done!
Hello Ixnachen, your idea really resonates with me—I originally found the Brimnes furniture a bit sterile as well.
Recently, I tried painting a door with chalkboard paint to use it as a weekly planner—it worked surprisingly well. However, I realized that you need to sand the surface thoroughly first; otherwise, the paint won’t adhere properly.
I can definitely confirm that. What made me a bit hesitant was the load-bearing capacity after making modifications. Especially when drilling into the wall or load-bearing parts, it’s easy to feel uncertain. I hope more advice on safe implementation will be shared here.
Wishing you the best of luck with your project, and if I have any more questions, I’ll be sure to reach out.
Svenja7 schrieb:
Basically, you can do quite a bit with Brimnes furniture:
To complement the previous contributions:
- The Brimnes series mainly uses particleboard with a melamine resin coating, which is not designed for constant moisture exposure or intensive mechanical processing.
- For successful painting, it is recommended to start with fine sanding (grit 180-220) to slightly roughen the surface. Then, apply an acrylic-based primer to reduce adhesion problems.
- Veneers or laminates should be cut as accurately as possible and should not create tension, as this can cause bubbles.
- For lighting, LED strips with a self-adhesive backing are recommended; their low weight and minimal heat generation are ideal for the furniture.
- Screws and drill holes should not be made near load-bearing connectors to avoid compromising structure and stability.
A tip: In high-stress areas of furniture, reinforcements with brackets or additional screws are advisable. When replacing handles, pay attention to the drilling distance to avoid large holes on the front.
