ᐅ How can I customize Ikea BESTA fronts with fabric or wallpaper?
Created on: 15 Mar 2023 18:07
Neo62
Neo62
15 Mar 2023 18:07
Hello everyone, I plan to customize my Ikea BESTÅ cabinet fronts with fabric or wallpaper and am looking for effective, practical methods. I’m particularly interested in how to best attach the fabric or wallpaper so that it adheres well and remains durable in everyday use. Are there specific adhesive techniques or materials I should consider? It would also be great if someone has experience with how easily the fabric can be removed later, in case I want to redecorate. I am planning to cover the fronts with both fabric and wallpaper, so a comparison of advantages and disadvantages would be very helpful. Thanks in advance for any tips and advice!
NUPIN
15 Mar 2023 20:23
Neo62 schrieb:
how to best apply fabric or wallpaper so that it adheres well and remains durable in everyday use.
This is definitely an exciting project! I covered my BESTÅ fronts with fabric, and what worked great was a combination of spray adhesive and double-sided specialty tape. This keeps the fabric firmly in place without causing wrinkles.
I definitely recommend using a high-quality, washable upholstery fabric and applying it with a bit of tension to ensure a smooth finish.
Neo62 schrieb:
whether the fabric can also be easily removed later in case you want to redecorate.
In the end, the adhesive holds quite well, but with some patience, you can remove everything later, especially if you don’t use overly aggressive adhesives. I tried this during my last update and was able to remove the textiles without any damage.
Good luck, it’s really fun and gives the room a completely new atmosphere!!!
Gafiel
16 Mar 2023 07:52
To add to Neo62’s question and the already helpful input from NUPIN, I would like to go into more detail regarding the preparation and gluing process for fabric or wallpaper applications on Ikea BESTÅ fronts.
First, it is important to know what material the fronts are made of (usually MDF panels with a melamine foil). This affects the choice of adhesive, as not every glue sticks equally well to melamine.
For wallpapers, solvent-free, strong vinyl adhesives or spray adhesives designed specifically for smooth surfaces work best. It is important to lightly roughen the front’s surface before gluing—using fine sandpaper (grit 240 or finer)—to improve adhesion. Afterwards, remove the dust with a lint-free cloth.
For fabrics, the material matters: cotton, linen, or synthetic upholstery fabrics work well, but here too, the choice of adhesive is critical. Spray adhesive with permanent bonding is optimal; however, you should test whether the fabric can be removed if desired. The adhesive must also be flexible enough to withstand movements of the front caused by temperature changes.
Another important aspect is the tensioning technique: slightly overlapping the fabric, neatly folding the edges, and possibly securing them with fabric tape or bias tape can ensure a clean finish. Especially for furniture with drawers or doors that are frequently used, a firm but flexible hold is essential.
If you prefer wallpaper, you can also try using an iron-on fleece combined with vinyl wallpapers to increase durability. When removing it, warm water and an old putty knife often help to thoroughly loosen the adhesive.
One more question: How are the fronts on your BESTÅ units constructed? Are they still the older, thin MDF panels, or the newer ones with thicker edges? This somewhat affects the gluing method, especially around the side transitions.
Happy to provide more details if needed!
gesar32
17 Mar 2023 14:38
After a thorough analysis of previous suggestions, I would recommend the following structured approach for customizing IKEA BESTÅ fronts with fabric or wallpaper:
- Preparation: The fronts must be clean, free of grease, and smooth. Before applying adhesive, it is advisable to lightly sand the surfaces with fine sandpaper and completely remove all dust.
- Material selection: For fabric, upholstery fabrics with a tight weave that fray minimally are best. For wallpaper, vinyl or vinyl-coated wallpapers are recommended as they are durable and washable.
- Adhesive: For fabric, acrylic-based spray adhesives with permanent bonding are ideal because they provide flexibility. For wallpaper, standard wallpaper paste suitable for vinyl should be used, as it absorbs moisture well and adheres firmly to smooth surfaces.
- Technique: When applying, it is important to stretch the materials tightly and avoid air bubbles. For corners, folding the material with fabric tape or masking tape provides extra support.
- Durability and removal: Fabric and wallpaper should hold well with the correct adhesive choice but are not suitable for heavily used fronts (e.g., areas frequently exposed to moisture). Removal can be labor-intensive and may require special solvents or mechanical methods, so this should be considered when selecting adhesive.
Finally, a note that when working with IKEA BESTÅ fronts with painted or laminated surfaces, aggressive solvents must be avoided to prevent damage.
If there are any questions about specific product choices, I am happy to provide further recommendations.
