ᐅ How can I creatively customize Ikea Besta fronts using fabric or wallpaper?
Created on: 19 Sep 2018 08:23
duncan37Hello everyone,
I recently bought some Ikea Besta cabinets and am now considering how to creatively and individually decorate the fronts with fabric or wallpaper. I find the standard fronts a bit plain and would like to add a personal touch without too much effort or permanent changes since I also want to try different looks from time to time.
Does anyone have experience with the best way to apply fabric or wallpaper to Besta fronts? Which materials work particularly well to ensure a durable and neat appearance? Are there any clever techniques to make the covering easy to replace later, or special adhesives that don’t leave residue?
Additionally, tips on surface preparation and care after applying the covering would be helpful, as well as recommendations for patterns or fabric types that are especially suitable for cabinet fronts.
I look forward to your creative ideas and examples!
luAlbert119 Sep 2018 21:44duncan37 schrieb:
Does anyone have experience with the best way to apply fabric or wallpaper to Besta fronts?Interesting question! I find the idea of decorating cabinet fronts with fabric or wallpaper generally much more exciting than just using paint or vinyl. However, I also want to point out that many DIYers often chase an aesthetic ideal that doesn’t actually last as long as they hope. Over time, these materials—especially on high-traffic surfaces like fronts—usually don’t hold up as well as expected.
duncan37 schrieb:
Which materials work best to keep things durable and looking neat?Personally, I think linen fabrics are the more elegant option because their texture brings furniture to life. But caution is needed here: linen can wrinkle easily and wear at the edges. If you want to avoid that, you might want to go for more durable upholstery fabrics or stick to high-quality wallpapers with a water-resistant surface. The glue is the tricky part! I wouldn’t rely only on wallpaper paste but consider using strong double-sided tape or special spray adhesives. These can be hard to remove without residue but work for a medium-term solution.
I like your idea of easy swapping. It’s important that you can remove the front—this makes the process much easier. Some users recommend attaching fabric with hook-and-loop tape (Velcro), so you can change it anytime without glue. That’s definitely the smartest method for changing designs regularly.
In short: if you want to change the look often, stay away from glue and use hook-and-loop or magnets instead. For longer durability: sturdy fabric plus spray adhesive or double-sided tape, but that involves more effort when removing.
luAlbert1 schrieb:
Personally, I consider linen fabrics to be the more elegant option because their texture brings furniture to life.That’s a good point, but as you mentioned, durability should be the main focus. Fabrics like upholstery velour or jacquard often work better than plain linen because they are more resistant to abrasion and dirt.
Regarding the technique: before considering adhesives, having a smooth and clean surface on the fronts is essential. It is recommended to lightly sand the fronts with fine sandpaper grit around 220 to achieve better adhesion.
For applying wallpaper, special high-adhesion glues are required, such as upholstery or contact sprays. These adhesives are suitable for furniture and dry without leaving residue.
Important: for fabric glue options, water-based spray adhesives are recommended as they do not harden or discolor the material. For a removable cover, hook-and-loop strips (Velcro) are the best choice, allowing you to change covers anytime without damage.
About patterns: small, subtle patterns tend to be more timeless on furniture, while large patterns can quickly dominate and visually shrink the piece.
duncan37 schrieb:
Does anyone here have experience with the best way to apply fabric or wallpaper to the Besta fronts?Hey, I decorated my Besta fronts the same way – and I can tell you, it’s really fun! 😄 My favorite method was using wallpaper-like non-woven wallpaper. It’s quite flexible, easy to cut, and very low maintenance. I fixed it with furniture tape, which works great, and I like the clean lines it creates.
RAKLO schrieb:
For a replaceable cover, Velcro strips are the best idea since you can change it anytime without causing damage.That’s a really great tip, thanks! I didn’t think of that at first, but with Velcro, I hung small pieces of fabric with different patterns right next to the fronts, so I can switch them anytime and change the room’s vibe.
Also, when choosing fabric, I made sure it wasn’t too thick so the door still closes well. And very important: good cleaning tips! I wipe my fronts with a damp cloth and avoid harsh cleaners.
Overall, this provides a great way to celebrate the seasons with new patterns or colors 😉. But if you’re looking for something more durable in the long run, heavy-duty upholstery fabrics, as RAKLO mentioned, are definitely worth considering.
