ᐅ How can I cover the surfaces of Ikea PAX wardrobes for protection?
Created on: 15 Mar 2019 20:12
SabinaHello everyone, I recently purchased an Ikea PAX wardrobe and now want to protect the surfaces, specifically the shelves and possibly the inner panels, from scratches, moisture, and general wear and tear. My exact question is: What materials or protective methods are best suited to effectively cover the surface of the Ikea PAX shelves without affecting their appearance or functionality? I’m looking for a solution that is durable, long-lasting, and if possible, easy to handle. Does anyone have experience or recommendations, perhaps with films, protective pads, specialty coatings, or other options? I look forward to your tips!
It is best to use self-adhesive protective film specifically designed for furniture. It is thin, transparent, and provides good scratch protection. Alternatively, non-slip felt pads can be cut to size and glued on – these also offer good protection and can be replaced when needed.
Hello Sabina, I will give you a structured response so you can proceed in a targeted way:
- First, you should consider the type of material used for the PAX shelves (usually melamine-coated or particleboard).
- For long-lasting protection, a transparent furniture or protective film based on PVC works well. Make sure it is adhesive-free or easy to remove in case you want to change something later.
- Another option is to use custom-cut protective mats made of transparent plastic (e.g., polycarbonate or PET). These are durable, non-slip, and protect the surface.
- Painting with clear varnish or polyurethane provides a smooth protective layer but is more labor-intensive and irreversible.
Common mistakes when applying films are air bubbles and edges that are not cut precisely. I recommend cleaning the surface thoroughly before application and carefully applying the film with a squeegee.
If you value sustainability, felt or wool pads are a good alternative, although they are more visible. In conclusion: for a balanced mix of protection and appearance, use high-quality protective films or mats specifically designed for furniture.
Guyju schrieb:
Painting with clear lacquer or polyurethane provides a smooth protective finish but is more labor-intensive and irreversible.This irreversible method is often underestimated. Clear lacquer might offer protection, but if you later decide you don’t like the color or finish, you’ll have to repaint the wardrobe or go through the time-consuming process of sanding it down.
I also think that covering visible materials with films or protective mats often makes them look “unnatural.” A PAX wardrobe is actually designed to showcase a clean interior. If protection is needed, it’s better to perform regular maintenance or at least opt for replaceable solutions.
What I still don’t understand: why not just use moisture-resistant shelves from Ikea for the surfaces? As long as your PAX model allows it, in my opinion this would be the cleanest solution—without the constant need to buy replacement films.
