ᐅ How can I apply adhesive film to IKEA Metod kitchen cabinet fronts?
Created on: 22 Sep 2017 18:37
Ginoplo
Hello everyone, I am planning to cover my IKEA Metod kitchen fronts with film to update the look without replacing the entire doors. Does anyone have experience with this and can share the best approach? Specifically, I am interested in tips on surface preparation, suitable types of film, application techniques, and whether any special tools are needed. It would also be helpful to know what to pay attention to around corners, edges, and handle cutouts to ensure the film lasts a long time without bubbles. I am reasonably handy but have only done small film projects before. Thanks in advance for your detailed and practical advice!
troyjon
23 Sep 2017 09:15
I would approach the handle cutouts in a similar way: first overlap the film, then cut with a utility knife. Press the edges down carefully, ideally using the felt edge of a squeegee. A heat gun helps to avoid wrinkles. For bubbles, always pierce with a needle and smooth out.
pautanner
23 Sep 2017 11:47
Hey, first of all, great job on the well-formulated question – it’s very precise! 😎 A small additional tip: When working on corners and edges, it can be helpful to warm the film slightly with a hairdryer while shaping it by hand. This makes the film more flexible and gives a more professional result. Another recommendation: After applying the film, make sure to roll over the entire surface thoroughly again with a squeegee to remove any remaining air bubbles. I used Metod films on my last kitchen, and despite all the preparation, small bubbles appeared, which luckily could be easily corrected with a needle and squeegee – so don’t get discouraged! A good tip: Don’t rush and work in small sections. Good luck!
Kinbu
23 Sep 2017 14:02
Additionally, I would like to point out that room temperature plays a crucial role when applying adhesive films: the ideal range is 20 to 25 degrees Celsius (68 to 77°F). If it is too cold, the film can become less flexible, which can cause issues especially around edges. If you use a heat gun, I recommend applying short, even bursts of heat to avoid overheating the film, as this can reduce its adhesive strength. Also, always use sharp blades when cutting — dull knives can tear the film or create uneven edges. Lastly, here’s a tip for preparation: remove electrical outlets or handles before applying the film to prevent rough edges or interruptions in the film.
