ᐅ How can I apply adhesive film to IKEA Metod kitchen cabinet fronts?
Created on: 22 Sep 2017 18:37
GinoploHello everyone, I am planning to cover my IKEA Metod kitchen fronts with film to update the look without replacing the entire doors. Does anyone have experience with this and can share the best approach? Specifically, I am interested in tips on surface preparation, suitable types of film, application techniques, and whether any special tools are needed. It would also be helpful to know what to pay attention to around corners, edges, and handle cutouts to ensure the film lasts a long time without bubbles. I am reasonably handy but have only done small film projects before. Thanks in advance for your detailed and practical advice!
Hello, your question is very well formulated and covers many important aspects. I would recommend first removing the fronts completely from the cabinet and cleaning the surface with a lint-free cloth and isopropyl alcohol to remove all grease and dust. For the film, self-adhesive PVC films with some texture are best, as they are resistant to scratches. When applying, a squeegee helps to press out bubbles right during application. Special care is needed especially at the edges: cut the film with a bit of extra margin and fold it inward. For cutouts, a sharp utility knife is essential to make precise cuts without tearing. If you like, you can also use a heat gun before applying to make the film more flexible. This improves adhesion, especially around curves.
As a preparation step, I would recommend lightly sanding the fronts beforehand – very fine, using 220 grit sandpaper. This improves adhesion of the surface. Then clean thoroughly, as mentioned before, and let it dry completely. When choosing the film, besides PVC, also consider so-called cavitation film or air-free technology, which allows for bubble-free application. Avoid cheap films that don’t have a nice texture, as this becomes noticeable quickly. Cut the film generously, more than you need, so you can adjust it precisely later. Warm the edges with a heat gun before shaping and pressing them down for better results. For cutouts, use a cutter with a ruler and preferably on a cutting mat. Also important: roll the film together with the front when unpacking it, as this reduces waves. How are you equipped with your tools? Do you have a felt-edged squeegee or just a simple plastic squeegee?
benonon schrieb:
What kind of tools do you have? Do you have a squeegee with a felt edge or just a simple plastic squeegee?Thank you for the detailed answer! I have a simple plastic squeegee and a standard utility knife. I also have a heat gun that I occasionally use for DIY projects. Sandpaper is available, but I was hesitant to use it because I didn’t want to alter the surface. Aren’t the Metod fronts more of a smooth lacquered or coated finish? I want to avoid roughing up the lacquer or having it become visible later. How much sanding would be necessary? And do you have any tips on how to best handle the handle recesses? Thanks in advance!
Metod kitchen fronts usually have a melamine resin coated surface or a painted finish, which is generally very smooth and relatively durable. Excessive sanding is not recommended, as it can damage the surface and negatively affect the adhesion of any film applied later, especially if the surface becomes porous. My advice: sand only very lightly with fine sandpaper (320 grit or finer) to create a slightly rougher texture. Clean the surface thoroughly afterwards. For the handle cutouts, cut the film generously, then use a utility knife to carefully follow the inner edges. Gently press the small strips of film onto the edges, warming it slightly with a hairdryer if needed to make the film more flexible. It is advisable to first carry out some test runs on scrap pieces to perfect cutting and adhesion.
