ᐅ How can I cover IKEA BESTA with paper and later remove it without leaving any residue?
Created on: 29 Mar 2022 19:42
Z
Zoelneo
Z
Zoelneo
29 Mar 2022 19:42
Hello everyone, I plan to cover my IKEA Besta furniture with paper to give it a custom design. I especially want to make sure that the adhesive and paper I use can be removed later without leaving any residue or damaging the surface of the Besta units.
So my questions are: What type of paper is best suited for this purpose? Are there any recommended adhesives or adhesive films that stick well but can be removed later without leaving residue? And are there any specific techniques or surface preparations that improve the adhesion process or make removal easier?
I have considered self-adhesive papers or washi tape, but I am unsure if these work well on a smooth, mostly lacquered surface like Besta, especially with regard to residue-free removal.
I would appreciate any tips, experiences, or warnings on this topic!
Mufato
29 Mar 2022 20:15
I covered my BESTA fronts with self-adhesive film. It is important to clean the surface thoroughly and make sure it is free of grease beforehand. For residue-free adhesive, I recommend removable adhesive films or special decoupage tape. Simply peel off carefully; any residue can be removed with isopropanol.
BENBI
30 Mar 2022 08:03
Hello, I would like to provide a detailed explanation about applying paper coverings to IKEA BESTA units, as there are some important details to consider. First: The surface of BESTA is usually melamine-coated, meaning it is relatively smooth, which generally makes adhesion easier but also increases the risk of adhesive residue if unsuitable glues are used.
- The best paper options are self-adhesive vinyl or photo paper, as they are thin, adhere well, and can usually be removed without leaving residue.
- I would not recommend traditional craft paper or regular printer paper because the adhesive tends to cause wrinkling and leaves residue.
Regarding the adhesive: Permanent glues should be avoided. Instead, “removable” adhesives, like those found in Tesa Style or 3M Command strips, are suitable. These adhere well but can be peeled off after some time without damaging the surface.
Preparation:
- Thoroughly clean the surface, avoiding oil-based cleaning agents.
- If the surface is not entirely smooth, it can be lightly dulled with fine sandpaper, but be careful.
Removal:
- Peel off slowly, preferably in small sections.
- Any residue can be carefully removed using a solvent like isopropanol, but test this first in an inconspicuous area.
One more question: Should the paper covering be permanent or temporary, for example, for an event or a property sale? This greatly influences the choice of materials.
karlau
30 Mar 2022 12:46
BENBI schrieb:
One more question on this: Should the adhesive be permanent or just temporary, for example for an event or a property sale? This greatly affects the choice of material.
Very good point! Sometimes people go overboard and want something like this on furniture for decades, even though it ruins the surfaces afterwards.
I also wonder: Who seriously covers their IKEA furniture with paper? Isn’t that more of a tool for photo shoots or trade shows? For everyday use, films or wraps are much more practical—and if you stick with white, it looks better anyway. But hey, to each their own.
Also, everyone should keep in mind that "residue-free" is relative. There are often slight traces left, especially with repeated applications.
andre3
1 Apr 2022 07:19
For an objective addition: Applying paper to IKEA BESTA furniture requires an optimized balance between adhesive strength and residue-free removal.
It is recommended to use:
- self-adhesive, removable vinyl paper with polyacrylate adhesive
- alternatively, paper combined with acrylic-based tape specifically designed for furniture
For surface preparation:
- clean with an alcohol-based cleaner (e.g., isopropanol) to remove dust, grease, silicone, or wax residues
- avoid sanding, as this could damage the melamine surface
For removal:
- peel off slowly at about a 45° angle
- any solvents used should be tested beforehand on an inconspicuous area
I recommend using high-quality adhesive films because paper itself is porous and may come off when exposed to moisture or mechanical stress. Also, caution is advised with UV exposure, as the adhesive tends to bond more strongly under such conditions.
In conclusion: the combination of PVC-free adhesive film and tested adhesives offers the best compromise between durability and residue-free removal.
