ᐅ How can I modify IKEA Metod cabinets for accessible living?
Created on: 11 Nov 2020 13:27
Parleo50Hello everyone,
I am currently planning an accessible living concept for my apartment and am wondering how IKEA Metod kitchen cabinets can be adapted for this purpose. I am particularly interested in what modifications are necessary to make the cabinets more accessible and functional for people with limited mobility or wheelchair users. I am looking for ideas that go beyond the standard dimensions, for example regarding height, handle types, and interior organization. Are there established methods to make the fittings more flexible or installation solutions that improve access? Perhaps someone also knows tricks to optimize storage space despite the accessibility adaptations. I look forward to your experiences, tips, or alternative ideas related to combining IKEA Metod furniture with accessible living.
Hey Parleo50,
your question hits the mark—accessible living is really important, and using IKEA Metod as a base is a smart choice! 😄
Personally, I would first make sure the cabinets are at a wheelchair-friendly height. The standard heights are often either too low or too high, so it’s better to cut down the legs and use adjustable metal feet that you can customize individually. And handles—replaceable! Lever handles or easy-to-grip bars work much better than traditional knobs.
A tip: soft-close drawers can be easily converted to full-extension drawers, so you can reach everything more easily, and rotating inner drawers are great when you don’t want to bend down much.
Of course, storage remains important, but with modular inner boxes at different heights, you get good organization and flexibility. Maybe consider a kitchen without upper cabinets, but with taller cabinets that have easily accessible compartments.
If space is tight: simple adapters for electronic openers or push-to-open mechanisms make handling much easier.
Overall: a bit of screwing, adapting, and clever planning—then accessible design works without stress!
JORDON schrieb:
And hey, handles – interchangeable! Levers or easy-to-grip bars are a great alternative to classic knobs.I also find this very important! For my mother, who is wheelchair-bound after a stroke, having especially easy-to-grip handles or even alternatives to knobs is essential.
I would also recommend using internal drawers with soft-close or self-close mechanisms, as they are much easier to operate and help prevent fingers from getting pinched or drawers from catching on cabinet doors.
A point that is very close to my heart is avoiding too many different opening mechanisms – the simpler, the better for all users, who may sometimes have limited strength.
However, it also takes some courage to change the standard layout in order to create more freedom of movement in front of the cabinets.
How have you planned to adjust the cabinet height exactly? Do you have any considerations so far? From my experience, a work surface height of about 85cm (33.5 inches) works well for wheelchair users.
To supplement the previous posts, here are some structured tips for modifying IKEA Metod cabinets in the context of accessible living:
- Work height: The standard height of 85 cm (33.5 inches) is optimal for wheelchair users but should be adjusted individually. This means the plinth height or the cabinet feet may need to be replaced or removed.
- Handles: Replacing handles with long or bar handles improves accessibility. Alternatively, handles can be swapped for handleless push-to-open systems, which can avoid motorization.
- Internal drawers: Full-extension drawers allow better access to the entire storage space. Internal drawers with smooth sliding mechanisms are recommended.
- Wall cabinets: Many accessible kitchens omit wall cabinets to create more maneuvering space.
- Wheelchair clearance: A free space under work surfaces of at least 70 cm (27.5 inches) height and 80 cm (31.5 inches) depth should be planned according to needs.
- Customization: Adjustable shelves or versatile inserts help adapt the cabinets to individual requirements.
These points are well supported by the modular design of the IKEA Metod series. However, prefabricated solutions are rather rare, and modifications usually require individual adjustments.
If there are further questions about specific components or materials, I am happy to provide more detailed information.
