ᐅ How can I modify an IKEA BESTA unit to use it as a shoe cabinet with proper ventilation?
Created on: 29 Aug 2016 14:03
MARON
I am planning to convert an IKEA BESTÅ into a shoe cabinet, but I have a specific concern: How can I modify this cabinet to ensure adequate ventilation? My main goal is to prevent my shoes from developing unpleasant odors or mold, since I want to store them inside the cabinet with the doors closed.
Since the BESTÅ components are usually made from very dense materials, I’m wondering what practical adjustments or additions can be made without compromising stability or appearance too much. Does anyone have experience or tips on ventilation solutions for the BESTÅ, such as vent grilles, special inserts, or other modifications? Any advice on suitable materials and tools would also be appreciated.
Thanks in advance for your suggestions!
MARON schrieb:
How large should these ventilation grilles be to ensure good airflow without losing too much heat or moisture?This depends largely on the room size and the level of humidity. For a typical room, a total cross-sectional area of about 20-30 cm² (3-5 square inches) of ventilation per compartment is usually sufficient to allow adequate air circulation without causing coldness or dampness.
MARON schrieb:
or open doors with grille inserts.This may seem practical, but it has the downside of altering the appearance of the cabinet and allowing more dust to enter. Additionally, you might then need some form of dust protection.
MARON schrieb:
How do I prevent unpleasant odors despite ventilation?Besides activated carbon, as mentioned earlier, it is advisable to regularly air out shoes before putting them away. Using shoe deodorizers or essential oils can also help. Most importantly, moisture should not remain inside the cabinet for prolonged periods.
I understand your concern very well, MARON. Shoes can really develop unpleasant odors when stored in an airtight piece of furniture.
If possible, try using removable inserts for the bottom of the cabinet that can be taken out and air-dried. This helps prevent dampness and stuffiness.
I can see that you want the cabinet to look nice. That’s why I like the idea of hidden ventilation grilles—they appear discreet but can be very effective.
If you experiment with active fans or something similar, please let us know how it goes! Others could benefit from your experience.
Ianlau schrieb:
That strongly depends on the room size and the level of humidity.Good point – in addition to the room climate, I recommend not fully sealing the closet floor surface, for example, avoiding a continuous solid floor panel and instead using a perforated or grid-type surface.
To achieve simple active ventilation, small, quiet fans can be installed in the back panel area, connected to a humidity sensor. Although this is somewhat more complex, it is particularly useful for damp shoes or for people who tend to sweat heavily.
It also makes sense to allow airflow at the lower rear section and to vent the used air at the upper back panel, enabling natural convection.
Hey, I find this DIY project really exciting! 🙂
I’m planning to use my BESTÅ as a shoe cabinet and have already been thinking about how to manage ventilation. The tips about using air vents are really practical.
One thing I’m curious about: Is it possible to design the cabinet with different compartments for sneakers, boots, and so on, while still ensuring good air circulation throughout?
Looking forward to more tips and experiences! It’s really motivating to gather ideas and get started!
FLONE41 schrieb:
If possible, try using removable inserts for the closet shelves that can be taken out and air-dried.I think that’s actually a very good idea, thank you! So far, I had only considered fixed shelves.
dopite schrieb:
To create simple active ventilation, you can also install small, quiet fans in the area of the back panel.That sounds interesting but is definitely a challenge. Are there fans available in sizes and noise levels that remain discreet? Or is this more of a DIY project for professionals?
ixlu1 schrieb:
Can the design be done in a way that the closet also has different compartments for sneakers, boots, and the like, while still maintaining good air circulation everywhere?I would also be very interested to know if modular solutions with separate air supply are feasible.
