I am currently planning to modify my Ikea Besta shelving unit to work optimally as a media cabinet. My goal is to create a compact yet flexible solution that can accommodate a TV, console, receiver, and possibly a soundbar or small speakers. It is also important to me to have intelligent cable management, as I want to keep visible cables to a minimum.
My question is:
How can I convert the Ikea Besta into a media cabinet that is functional enough for all media devices, visually appealing, and at the same time provides sufficient ventilation and accessibility? Are there any proven methods or custom builds you would recommend? I am especially interested in tips for precise custom fittings, cable drillings, as well as ideas for hidden compartments or modular add-ons that can be installed later.
Thank you in advance for your expertise!
My question is:
Hello Timothy,
your question is very well formulated and addresses many important points to consider when adapting the BESTA system as a media unit. I myself redesigned my BESTA system some time ago and can share a few basics and tips with you:
- Cable management: Drilling holes in the back panels allows for easy cable routing. It is important to place the holes so that no load-bearing parts are damaged. IKEA uses relatively thin panels for BESTA, so I recommend using a Forstner bit to keep the edges clean.
- Ventilation: Electronics generate heat, so there should be openings for airflow in and out. You can, for example, add narrow ventilation slots in the middle or on the sides—either routed yourself or using a standard ventilation grille.
- Adjustable compartments: Shelves in BESTA are easily adjustable, so take advantage of that for different device sizes. If you want recessed compartments or sections with doors, choose frames with finger pulls to keep the look clean.
- Soundbar and speakers: For these, I simply extended my BESTA with an open compartment so the soundbar isn’t enclosed. This also has acoustic benefits.
- Additional modularity can be achieved by adding IKEA storage boxes or extra shelves.
I hope this helps you so far. If you like, I can also give you tips on drilling techniques or materials for a more professional finish.
Best regards!
Best regards!
GiRoyce schrieb:
Drill holes at the back of the rear panels to allow easy cable routing. It is important to place the holes so that no load-bearing parts are damaged.This is a very important point that GiRoyce mentioned. I would like to add some details that may be helpful during planning and implementation:
- Cable routing planning: I recommend measuring all devices first (connectors, cable lengths) and determining the ideal position inside the BESTA cabinet. Then mark the drilling spots precisely, preferably using templates or drill guides.
- Use cable grommets with brushes or rubber seals. This not only protects the cables from damage caused by rough edges but also creates a neater appearance.
- Ventilation: If you plan to have more enclosed compartments with doors, it is advisable to install ventilation openings of at least 5–10 cm (2–4 inches) on the back panel or bottom of the compartments. If the electronics generate significant heat, a small, quiet fan mounted discreetly at the back could also be an option.
- Material reinforcement: Since the BESTA system is made from relatively thin particleboard, you can reinforce the inside with strips or metal brackets if you expect frequent modifications or want to improve stability. This prevents shaky constructions and extends the furniture’s lifespan.
- Painting or covering after modification: To neatly cover marks from processing (drill holes, milling), I recommend painting afterward or applying furniture film that matches the color of the rest of the BESTA system.
- Finally, a question for you: What is the size of your room, and do you plan to combine the media furniture with other pieces that need to be considered in terms of style and color? This is relevant for choosing colors and materials.
I’m happy to provide more detailed advice if you share your specific conditions.
Timothy,
I would like to add to your question from a structured perspective. To convert Ikea BESTA into a functional media unit, I recommend systematically addressing the following points:
- Device Inventory: Create a detailed list of all devices including dimensions and connection types.
- Storage Planning: Calculate the required depth and height for each compartment, especially for receivers and consoles that need ventilation and accessibility.
- Technical Modifications: Plan holes for cable passages, minimizing their number and size to maintain stability.
- Modularity: Use modular BESTA units that can be connected or screwed together to allow later adjustments if needed.
- Lockable Compartments: If devices need protection from dust or restricted access, incorporate doors with ventilation slots.
- Appearance: Consider that large-scale drilling or modifications will require finishing work (e.g., painting, cover caps).
I believe a step-by-step approach is optimal, starting with measuring and planning, followed by technical implementation, and finally visual fine-tuning.
If you provide specific measurements or device names, more precise advice can be given here.
Maria35 schrieb:
I believe a step-by-step approach is best, starting with surveying and planning, then technical implementation, followed by final aesthetic touches.Absolutely correct. To put this plan into practice, I can recommend the following procedure, which I used myself in a similar project:
1. Create planning sketches: Draw your desired media furniture, including all devices and cable routes, ideally on millimeter paper or using CAD software. This helps avoid errors and necessary modifications.
2. Set up a prototype: If possible, assemble the BESTA modules temporarily to check if all devices fit and if air circulation is sufficient.
3. Drilling with protection: Use special drill bits with depth stops to prevent accidentally drilling through or damaging the back panel.
4. Install cable management elements: Cable clips, hooks, and grommets help keep things organized and make maintenance or future modifications easier.
5. Realistically plan ventilation using ventilation grilles or routed openings, depending on the heat generated by the electronic components.
6. After completing the modifications, smooth all edges with sandpaper and touch up with color-matched caps or filler as needed.
I would also like to know whether you plan to add doors and what color the BESTA carcass is, so any paint or foil can be better matched.
