ᐅ How can I configure Ikea PLATSA as a wardrobe cabinet?
Created on: 12 Dec 2021 08:26
Jenon
Hello everyone, I finally want to configure a functional wardrobe closet using the Ikea Platsa system, but I am a bit uncertain about the detailed planning. My main concern is that the closet provides enough space for jackets, coats, and shoes while remaining flexible in case I want to make changes later. It should also be as compact as possible and fit well in a hallway with limited space (about 150 cm (59 inches) wide, 60 cm (24 inches) deep, 200 cm (79 inches) high).
Can you offer tips on how to ideally configure PLATSA as a wardrobe closet? Which components are essential to ensure functionality? Are there recommendations on the dimensions and modules that work especially well for this? Practical advice on assembly and how to combine hanging rods and shelves would also be very helpful.
RENMA
13 Dec 2021 08:39
Jenon schrieb:
Could you please explain how flexible the depth layout is?
The Platsa modules come with a standardized depth of 60 cm (24 inches), ensuring uniformity and stability. There are no officially available modules with different depths in the range. Individual elements such as drawers or hanging rods within a module are designed to fit the 60 cm (24 inches) depth.
To achieve a different depth, you would need to modify or creatively use shelves, but this could affect the overall stability. Recommendation: stick to the standard depths for wardrobe furniture.
Keatondra
13 Dec 2021 12:22
I can only add that the PLATSA series is quite beginner-friendly. The plug-in systems make it easier to assemble the modules, and the outer cladding provides stability. Make sure that if you plan hanging rods, the height is at least 120 cm (47 inches). For shoe racks at the bottom, I have had good experiences with slanted shelves, as they allow the shoes to breathe better and look nicer. The option to mix doors and other fronts is also great for customizing the wardrobe to your style.
SauDietmar
14 Dec 2021 10:05
Here is a brief guide for the configuration:
- 2 modules, each 75cm (30 inches) wide, placed side by side
- 1 module with a hanging rod at 120cm (47 inches) height for coats
- 1 module with 3 to 4 shelves for shoes and accessories
- At the bottom, a shoe basket or an open compartment
- Optional doors for a tidy appearance
A common mistake is underestimating the height needed for coats. It’s better to allow a bit more clearance at the top, otherwise the items will hang flattened.
JEREMIAH38
14 Dec 2021 14:47
I completely agree. At first, I only allowed for 100cm (40 inches) of height and had to adjust later because my coats are very long. It’s better to plan with plenty of space.
Also, I would recommend not overlooking baskets as an addition since they are flexible and allow you to quickly toss items in without creating a mess.
sanjon
15 Dec 2021 08:13
For easier handling:
- PLATSA modules are usually recommended as components measuring 75x60x200 cm (WxDxH) (approximately 30x24x79 inches),
- A hanging rod for clothes and coats,
- Shelves for shoes and small items,
- Doors optional depending on preference,
- Use the included mounting brackets for assembly to ensure stability.
Jimte
15 Dec 2021 08:56
If you use PLATSA as a wardrobe, plan to include drawers for small items and leave an open space at the bottom for shoes. This saves a lot of searching.
