ᐅ How can I combine IKEA Besta units with a countertop?
Created on: 20 Dec 2023 14:07
Caleb57
Caleb57
20 Dec 2023 14:07
I am planning to combine my IKEA Besta shelving unit with a countertop to use it as a storage and work surface in the living room. The challenge is to find a suitable countertop that is sturdy enough, easy to install, and visually matches the IKEA Besta system, as I want to maintain the clean lines and modern look of the unit.
I am particularly interested in which materials and mounting methods have proven effective. Should I opt for a thick solid wood countertop, or is MDF with a laminate sufficient? How can the countertop be attached so that it doesn’t slip, without damaging the shelves inside?
Does anyone have experience with having the countertop cut to size or with edges that are already pre-finished upon delivery?
I look forward to tips, tricks, and experiences from those who have already built or planned this kind of combination.
PeoDaniel
20 Dec 2023 14:29
Hello Caleb57,
Your project is quite popular, and many IKEA Besta users ask the same question. Generally, there are a few important factors you should consider:
- Choice of material: Solid wood panels look high-quality and are sturdy, but they tend to be more expensive and heavy. MDF or particle boards with a laminate surface can be more affordable, but they usually are less durable and may swell if exposed to moisture.
- Stability: The countertop should be at least 2 cm (0.8 inches) thick to ensure it is stable enough and does not bend. This is especially important if you plan to place delicate appliances on it.
- Attachment: You can fix the panel, for example, using screw-mounted brackets or tension strips, which are screwed under the panel and to the Besta frame. This prevents the panel from slipping and still allows you to replace it if needed.
- Cutting and edges: IKEA offers cutting services on request; alternatively, you can buy cut-to-size panels at hardware stores or choose a ready-made countertop. Make sure the edges are smooth and sealed to prevent water from seeping in.
If you want more details on specific materials or tools, just let me know! Good luck with your project!
Davidleo
20 Dec 2023 15:56
Hey Caleb57!
Great idea to equip the Besta shelf with a countertop – it definitely looks very elegant! 😄 I did the same and am really happy with it.
Here’s a quick summary of my experience:
- I chose a 3 cm (1.2 inch) thick oak countertop, which I had custom cut by a carpenter. Not cheap, but the surface feels very high quality.
- I attached it using small metal brackets screwed in between the shelf and the countertop from the inside. They stay hidden and hold firmly!
- Tip: Before screwing it down, cushion the countertop with anti-slip mats to avoid scratches and prevent shifting.
If you need a little encouragement: just go for it! It really turns out great, and you get a genuine designer piece 😎👍
CHENFAR
21 Dec 2023 09:13
To supplement the previous contributions:
From a technical standpoint, the choice of countertop is best based on the intensity of use and the environment (e.g., moisture level).
Recommended options are:
- Melamine resin-coated chipboard (MDF) with a thickness of 2-3 cm (0.8-1.2 inches): cost-effective, easy to maintain, and sufficiently stable for normal use.
- Solid wood boards are visually appealing but more susceptible to moisture and require regular maintenance (oiling or varnishing).
For mounting:
- The most common method is to use angle brackets, which can be screwed under the countertop to the Besta shelf without damaging the shelf.
- Alternatively, many fabricators offer tongue-and-groove joints or clamping profiles; however, these are usually intended for custom-made solutions.
Please note:
- The weight of heavy countertops can affect the stability of the shelves, especially if the shelf legs are not designed accordingly.
- Therefore, additional supports or reinforcements are recommended for thicker countertops above the standard Besta height.
Finally, plan exact measurements in advance and consider the correct alignment of the countertop to minimize any adjustments afterward.
Ramon4
21 Dec 2023 11:42
Hello Caleb57,
I’d like to add a few practical tips:
- If you want to cut the board yourself, a router with an edge-trimming bit is helpful to give the countertop edges a professional finish and prevent splintering.
- For fastening, I personally use small screws with washers to better distribute the load on the screw heads – this helps avoid cracks in the board.
- Be careful not to tighten the screws too much to prevent excessive tension.
- When choosing the countertop, I would recommend a particle board with a melamine coating, as it is easy to maintain and reasonably priced.
If you like, I can also put together a material list and tool recommendations for you.
In general, I have found that the combination of Besta + countertop creates a very functional and visually appealing piece of furniture.
If you have any questions about the assembly, feel free to ask!
Caleb57
21 Dec 2023 17:54
CHENFAR schrieb:
Please note:
- The load on shelves from heavy countertops can affect stability, especially if the shelf supports are not designed accordingly.
That’s an important point, thanks for mentioning it. I’ve also been considering whether additional bracing might be necessary. Has anyone had experience with the best ways to reinforce this? Are there specific leg models from IKEA or other manufacturers that can be retrofitted to improve stability with a heavier countertop?
Additionally, I would like to know if anyone has experimented with transparent adhesive pads or similar solutions to prevent slipping without using screws, as I don’t want to alter the appearance too much.
