ᐅ How can I combine Ikea Besta furniture with natural wood fronts?
Created on: 12 Feb 2024 09:23
mautra
mautra
12 Feb 2024 09:23
Hello everyone, I am planning to furnish my living room with Ikea Besta units, but I would like to incorporate natural wood fronts as much as possible. My question is: how can I combine Ikea Besta units with natural wood fronts without making the overall look too busy? It is important to me that the combination appears harmonious while still maintaining the typical Scandinavian style with a natural, warm feel. Do you have any experience or tips on how to choose suitable wood fronts or even create them yourself? Also, which colors and finishes work best with the usually white or black Besta cabinets? Thanks for your suggestions!
peovin
12 Feb 2024 09:56
I would make sure that the wooden fronts have a clear, consistent grain and choose light colors like oak or birch. This keeps the combination with the white Besta carcasses calm and modern. If you want to make the fronts yourself, simply brighten and protect them with an oil or wax.
Palenar
12 Feb 2024 10:44
The combination of Ikea Besta units with natural wood fronts is an interesting topic that requires careful planning. First, you should ensure that the wood types match in tone and grain. Ikea Besta cabinets are often available in white or black, which can create a strong visual contrast. Natural wood fronts like ash, oak, or maple work very well together, as long as they have a matte finish—high-gloss surfaces would diminish the natural appearance.
An important technical aspect is the attachment of the wood fronts. Ikea’s original fronts are usually lacquered, so using regular wood may lead to tension issues. Therefore, I recommend applying a uniform primer and fine sanding before installation. You should also consider whether you want continuous fronts or a mixed look combining wood and white fronts. It can be helpful to design individual modules as focal points with wood while keeping others simple.
Is your room lighting rather cool or warm? Warm LED lighting enhances the natural warmth of wood tones. One more question for you: what are the intended uses of the furniture? TV unit, sideboard, or storage? The context often determines the best choice of materials and maintenance.
tutan
12 Feb 2024 11:12
Hey, great question! 😄 I think natural wood fronts always bring a cozy atmosphere to a room. The Besta series, combining white carcasses with wood fronts, almost feels like the perfect mix of modern and homely. Also, there are films that look like real wood if you don’t want to stain the fronts yourself.
If you’re a bit adventurous, you could experiment with different types of wood – for example, light oak for the doors combined with a darker walnut tone as an accent. This way, you create a lot of depth in the room, and it doesn’t become boring. 😉
My tip: Always pay attention to the color temperature contrast! If you use brown wood fronts, you should keep the carcasses light; otherwise, the space can quickly feel too dark and heavy.
juMira46
12 Feb 2024 12:37
Hello, I recently completed the exact same project and can say from experience: natural materials and Ikea go perfectly together! Oak or birch wood fronts work especially well with the white Besta frame.
It’s important to choose wood fronts with a matte finish – this looks much more elegant than gloss and feels far more natural. Also, if you are painting the fronts, I recommend using a water-based paint without a strong yellow tint to keep the wood looking authentic.
If you want to add a bit of color, you can complement the design with small details like green plants or textiles. This makes the overall look lively without being overwhelming.
mautra
13 Feb 2024 08:15
Palenar schrieb:
An important technical point is the attachment of the wooden fronts. Original fronts from Ikea are usually painted, which could cause tension with untreated wood. Therefore, I recommend a uniform primer and fine sanding before installation.
Thank you for this advice, I wasn’t aware of that! I actually plan to make the wooden fronts myself to match the exact color. Do you know which primer works best to prevent the wood from warping and to keep the front stable over time? Also, a question for everyone: What about the maintenance of wooden fronts? Should I expect intensive ongoing treatments?
