ᐅ How can I clean Malm furniture more effectively?
Created on: 16 Mar 2024 08:37
edelhard
edelhard
16 Mar 2024 08:37
I have an IKEA Malm bed frame made of white painted wood and would like to know the best way to clean this furniture without damaging the surface or affecting the paint. It has a matte finish that shows some light signs of use. I want to avoid the furniture becoming dull or stained, as can sometimes happen with the wrong cleaning products.
Are there any specific cleaners or cleaning methods that have proven effective for keeping Malm furniture durable and clean?
I look forward to your tips and experiences – I’m especially interested in whether home remedies are recommended and which tools work best (e.g., microfiber cloths, sponges, etc.).
TEOZAR
16 Mar 2024 09:12
Hello edelhard,
I understand your concern, as many Malm furniture pieces have a matte finish that can be easily damaged if not cared for properly.
In general, I recommend avoiding harsh cleaners and instead using lukewarm water with a mild dish soap. It is important to use a soft microfiber cloth and avoid abrasive pads, as these can scratch the surface.
After cleaning, it is best to wipe the area with a dry, soft cloth to prevent water spots.
Home remedies like vinegar or citric acid are not recommended because their acidity can damage the finish.
For tougher stains, you can gently try adding a small amount of glass cleaner to water, but please test very carefully first.
I hope this helps you as a first guideline. 🙂
Nathanaelk
17 Mar 2024 14:45
Hello edelhard and interested readers,
I would like to delve deeper into the topic of cleaning IKEA Malm furniture, especially since matte lacquered surfaces have some particular characteristics.
1. Material and Coating: The Malm series typically uses a melamine resin or polyurethane coating, with the matte appearance achieved through a special matting process. While this layer is resistant to scratches and water, it is sensitive to harsh chemicals and mechanical stress.
2. Cleaning Techniques:
- First, dust should be removed with a dry microfiber cloth. Avoid dry cloths with high friction as they can cause micro-scratches.
- For routine cleaning, I mix 1-2 drops of a mild, pH-neutral dish soap with warm water. This method does not damage the surface and effectively removes dirt.
- Use a microfiber cloth that is well wrung out to prevent moisture from seeping into the seams.
3. What to Avoid:
- Abrasive cleaners, steel wool, or harsh chemicals (e.g., ammonia, alcohol, or solvents). These substances can especially make the coating dull or sticky and cause irreversible damage.
- Excessive water at once—standing moisture can penetrate edges and cause swelling.
4. Stains and Maintenance:
If you have stubborn stains, first test a very mild cleaner on an inconspicuous area—for example, a brief and infrequent application of a 70% isopropyl alcohol-based solution.
Finally, you can use a specialized care product for lacquered furniture to maintain the matte finish and provide light surface protection. Before using, carefully read the product description and, ideally, test it first.
One more question for you: What specific types of stains or wear marks are you trying to remove? That might influence the cleaning method.
koduga
18 Mar 2024 10:22
Nathanaelk schrieb:
One more question for you: What kind of stains or signs of wear are you specifically trying to remove?
I think this is a very important point because not all stains can be removed equally well with the same methods.
Sometimes it’s easy to feel overwhelmed and uncertain, especially since furniture pieces like the Malm bed frame are often connected to sentimental memories.
I once worked with a similar piece of furniture that had slight beverage rings and fingerprints as an issue. What helped me was very gentle cleaning with lukewarm water, a drop of dish soap, and a very soft cloth.
If you describe exactly what bothers you most about your furniture, the community can give you more targeted advice – and you won’t feel so alone with your concerns.
I’m keeping my fingers crossed that you find a good solution. 🙂
