I have several IKEA Brimnes furniture pieces at home, including sideboards, wardrobes, and nightstands. Since the surfaces are mostly made of coated wood-based materials, I’m unsure how to clean them most effectively and with minimal effort without damaging the surface. Can you give me tips on how to clean BRIMNES furniture, which cleaning products are suitable, and the best way to remove dust and stains? It is especially important to me to avoid using too many different products and to keep the furniture looking good for as long as possible. What is your cleaning routine when caring for BRIMNES furniture at home?
In summary, I recommend the following steps for cleaning IKEA Brimnes furniture to minimize effort and reduce the risk of damage:
- Wipe daily with a soft, dry cloth
- For dirt or stains, clean with a well-wrung microfiber cloth dampened with water and a mild dish soap solution
- Dry immediately, avoiding any standing moisture
- Do not use aggressive cleaners or abrasive materials
The key point is to dry the furniture immediately to prevent moisture from penetrating the surface. If the furniture is used frequently, a weekly check and cleaning is advisable.
Joshbe schrieb:
Dry immediately, do not allow any standing moistureI can only confirm this. A small addition: if dirt appears that cannot be removed with dish soap, a slightly damp cloth with some vinegar water (1 part vinegar to 3 parts water) helps. Vinegar works well to remove lime and grease residues. However, do not use too much moisture and always wipe dry immediately afterward.
And to minimize effort once again: regular dusting is really the best protection against widespread dirt buildup.
