ᐅ How can I childproof IKEA BESTA doors easily and without much effort?
Created on: 27 Mar 2020 14:18
pra35
pra35
27 Mar 2020 14:18
Hello everyone, I have a question regarding my IKEA Besta cabinet doors. My young daughter has recently started crawling around the apartment, and I want to prevent her from opening the doors and potentially damaging anything stored inside. I am looking for a way to childproof the IKEA Besta doors without much effort or requiring special tools. It is important to me that the solution is reliable, does not negatively affect the appearance, and ideally can be removed without leaving any residue if I no longer need it. Do you have any tips on products or methods suitable for securely locking the doors? Thanks in advance for your suggestions!
maureo
27 Mar 2020 14:45
For your IKEA BESTA doors, I recommend simple snap locks for cabinet doors. They can be installed without drilling using adhesive pads and hold well. Alternatively, you can use plastic toggle latches, which usually can be removed again without leaving any residue.
Guyju
27 Mar 2020 16:07
Hello pra35,
I completely understand your concern, as safety is the top priority when it comes to young children. I suggest the following:
1. Choosing the right child safety lock: For IKEA BESTA doors, clamp or adhesive systems work best. It is important that the installation does not require drilling to avoid damaging the cabinet.
2. Products with self-adhesive Velcro pads or strong adhesive strips provide good grip, such as special child locks for cabinets and doors. Simply attach them on the inside of the door and the frame.
3. Make sure the surfaces are clean and dry before installation, otherwise the lock will not hold properly.
4. Test the solution multiple times after installation for stability and ease of use, so you know how difficult it will be for the children to open but you can still access items quickly.
5. If the cabinet is a bit deeper, magnetic locks with a key are also helpful. These are easy to install and offer high security.
In summary, choose a product that is easy to install and removable without residue, and that works well on smooth surfaces like those used by IKEA. Also, ensure that your daughter cannot reach any other lever mechanisms.
If you like, I can provide some specific product recommendations.
kaju67
28 Mar 2020 09:33
pra35 schrieb:
Now I am looking for a way to childproof the IKEA BESTA doors without much effort or needing a lot of tools.
I know that all too well when little ones start discovering everything that isn’t nailed or screwed down! Back then, I simply bought flexible strap locks that were easy to install. No drilling, just strong adhesive – and they work surprisingly well. They’re almost invisible and can be quickly removed if needed.
Sometimes I also try using small magnetic locks. They are minimally visible and make it almost impossible for kids to get inside. A bit more effort to install, but very practical in the long run.
I also think it’s important that the locks don’t annoy you during daily use. If a caregiver can quickly click or pull them open, that’s a big advantage.
If you choose plastic locks, make sure they are of good quality, as some cheap versions come loose quickly. And stay firm when the little ones try to get at them – with patience, it will work out fine!
LAURE-TA
28 Mar 2020 19:24
Hello pra35,
I would like to add a few tips on how to childproof IKEA BESTA doors without much effort.
First, clamp locks work very well because they can be installed without tools. They usually grip around the door handle and prevent it from opening. Advantage: no residues, no damage.
Second, magnetic child locks are highly recommended, mounted inside the cabinet. Although they require a bit more effort to install, they are completely invisible from the outside. In daily use, you only need a small metal key or tool to open them.
Third, you should especially pay attention to material compatibility to avoid any adhesive residues when removing the locks. Using a hairdryer carefully can help loosen the adhesive without leaving marks.
In conclusion: even if you don’t want to drill much, there are sturdy solutions with adhesive strips or tension locks that provide a good level of safety. For quick fixes, sets with several clips are practical if you need to adapt different cabinets.
If you want to get more specific about which bars, fittings, or locks work best, I’m happy to help.
